Scratched Windscreen........
Hi guys, my screen is getting really scratched by the wipers
(to the point that it will need polishing) but I really don't think they are worn out, what could it be?
Re: Scratched Windscreen........
If your screen is old it may be pitted as well as scratched.
Thus all the gunk from using the car will get trapped in these areas on your screen.
Clean your wiper blades or change them.
Thoroughly wash your screen and apply a screen polish, and keep repeating if it still catches the gunk.
.if after say half a dozen attempts it does not improve I can only suggest a new screen.
Hmm cheers guys, I will get onto new blades 2moro, what kinda price are they and can I get them from anywhere e.g.
Kwik Fit?
Here are the blades up close:
They are big scratch marks in the way the wipers sweep across the screen, I can never hear the scraping but I'm assuming it's the plastic bits that hold the rubber on, as they line up with the marks! What a pain!!
Cheers fella, ur always a massive help!
SwissHeavy wrote:Cheers fella, ur always a massive help!![]()
no problem, also make sure you get the right fitting
On the subject of scratched windscreens.
I've managed to scratch the passenger side
- i nice arc where the 2 metal strips decided to poke out of the end of the blade housing.
my question.
can the scratch be polished out
also got a stone chip
(very very small) right in my eyeline
(not enough to fail an MOT) can they both be done
thanks.
my question.
thanks.
Yeah u should be able to mate, I know Autoglass do it
(which is where I'll be going) and u can get polish kits.
from somewhere! lol
If your mr2 is an import
- dont bother with halfords.
When i went there i found out the bosch wipers have a different fitment
- go for champion
- they'll fit.
Rev2_mike wrote:If your mr2 is an import- dont bother with halfords.
- go for champion
- they'll fit.
Sure you got the right ones?
I got my Bosch wipers from Halfords.
I haven't tried the champion ones though so couldn't comment on those.
CosmosblueMR2 wrote:On the subject of scratched windscreens..
my question..
thanks..
When they repair a scratch get them to polish the screen too.
Chipsaway cando windscreen repairs and polishing.
Dont need replacement blades, go to toyota and just get em to fit the rubber strips,bit expensive
£10 for 2.
that includes someone to do it as well lol.
.false economy otherwise.
I have a pitted windscreen now
gritters.
i got toyota to do mine change blades and labour to do them for 16 quid easy alson got thierr cheak and 4 cups of coffee
What is this screen polish of which you speak? I have lots of little scratches on my screen all over it.
I can see out of it fine but it can get a little bad in low sunlight.
Might be something i can use instead of replacing the screen
Just to update u fellas, u can't polish the screen, not professionally, because it can weaken the glass as it takes a layer off.
So a quote for windscreen fitted from autoglass
£450, wtf!
Auto Windscreens
£150, now that's more like it!
Josh
P.S Autoglym do a glass polish Sadako.
though how good it is I don't know.
Auto Windscreens
Josh
SwissHeavy wrote:Just to update u fellas, u can't polish the screen, not professionally, because it can weaken the glass as it takes a layer off..
You sure?
If it isn't a deep scratch, less than
So get the micromesh out and give it a go!!
