I've just completed an install myself on my Rev3, using only a pair of ramps, socket set, screwdrivers, knife, vice, drill, hammer and doing it outside.
All the info to complete the job is on here, every topic is covered, just use the search facility, or browse back through the topics.
The job does take quite a while, allow a weekend and take your time the nose needed to come off for me, although others without aircon have managed it without removing it.
You need to get under the car to route the pipes, not good if you are claustrophobic etc, and the undertrays need to come off.
If you feel unsure
I used:
ST205 Chargecooler core, Fensport,
Davies Craig EBP Pump, Demon Tweeks,
Fiat Cincequento Radiator, Brand New, Ebay,
Fiat Cincequento radiator fan switch, Breakers Yard,
10m of 19mm ID,25mm OD clear plastic pipe, Walker rubber and plastics,
ST205 air input connector
ST205 Throttle cable bracket, Toyota, T78024-88480
32/19mm Pipe reducers, B+Q
6 Stainless Steel jubilee clips,
Self Adhesive foil tape, B+Q,
1m 5mm Black rubber pipe, Walker rubber and plastics,
1m 12mm Black rubber pipe, Walker rubber and plastics,
1m pre drilled fixing strip, Wickes,
Bag of Ty-wraps, B+Q,
Total:
I could have saved a few quid by using the Demon Tweeks IMOC discount, and perhaps some from Mr T.
Oh, and don't forget Rory's temperature sensor mod to keep it in check, well worth the
Very comparable to a good Air/Air Intercooler price wise, read other posts for performance comparisons.
Many thanks to the people who thought of and developed this mod
cheers
Andy
Rev3 Turbo'd Chargecooled G-Limited
