HEADGASKEY FOOKED!
Dean
HEADGASKEY FOOKED!
Post by Dean »
just found out my HG gone!
question is what thickness should i go for now.....was thinking 1.4mm
dont really know much about this....any ideas?
cheerz
dean
Andy F
Re: HEADGASKEY FOOKED!
Post by Andy F »
Dean wrote:just found out my HG gone!
cheerz
dean
Stay standard fella, if it aint broke don't try and fix it!!
AM TUNING
Post by AM TUNING »
if your only running light engine mods i say go for a standard size metel one ,,
Dean
Post by Dean »
sorry abit of a copy n paste but this is my spec list so far;-
3mm blue vacuum hose
Air-Con removed
Apexi AVC-R
Apexi power intake
Arias Pistons (not yet fitted)
Aussie exhaust downpipe
Blitz High Pressure Radiator Cap
Blitz Nur spec R exhaust
HKS ssqv bov
Magncor 8mm leads - blue
NGK irdium grade 8 spark plugs
Owen Developments Stage2 turbo
Painted rocker cover and inlet manifold
Samco hoses
Sard adj FPR (not yet fitted)
TRD High Pressure Oil Cap
TRD oil filter
TRD thermostat
Trust Greddy Catch Can
Trust Greddy Intercooler
Uprated Fuel Pump, Walbro 255 Litre per hour (not yet fitted)
Uprated knock sensor
currently running about 1.2 - 1.3 bar and have plans for 500brake but can't afford to do all the internal mods just yet.
cheerz
dean
Andy F
Post by Andy F »
Dean wrote:sorry abit of a copy n paste but this is my spec list so far;-
Air-Con removed
Apexi AVC-R
Apexi power intake
HKS ssqv bov
Samco hoses
TRD oil filter
TRD thermostat
cheerz
dean
As before, just stay stock, examples
Ian ashton stock =560bhp
Dino stock = 400ish bhp
me stock= 430ish
the top 2 people really really know what the are talking about!!
nuff said
Dean
Post by Dean »
can you tell me why stock is better than an uprated one then??? or what the advantage/disadvantage of having a 1.4mm steel gasket in there???
cheerz
dean
Andy F
Post by Andy F »
Dean wrote:can you tell me why stock is better than an uprated one then??? or what the advantage/disadvantage of having a 1.4mm steel gasket in there???
cheerz
dean
The ideal HG thickness for good squish is 1.0mm. On a Rev1/2, this may be a bit too small (this might give too high a CR), but I would certainly not want to go for anything thicker than 1.2mm. Affecting the squish is just not worth it.
Dino explains these things better than me :roll:
JJ
Post by JJ »
No kidding !!! :lol: :lol: :wink:
Where is the old dog these days ??
Dean
Post by Dean »
i would of thought thinker and stronger would be better :?
cheerz
dean
MR2Mania
Post by MR2Mania »
Dean wrote:i would of thought thinker and stronger would be better :?
cheerz
dean
Thicker is not stronger (not the way you're thinking, anyway). The fact that they are metal gaskets on the Rev3 onwards, and they're of as good a quality as HKS ones, why pay £200+ when you can pay £30? Also, as Andy says, the thicker the HG, the more you get away from the ideal squish which affects the efficiency of the combustion process.
I see from your spec that you've got a Rev1? If so, then it's no suprise your HG has gone as it's a material-type one, not metal. I'd suggest either trying a 1.05mm standard Rev3 HG and adapting like AndyF has done, or going for the 1.2mm TTE ST185 HG. They're both as good as each other in terms of quality and reliability, although the TTE one will be closer to your current one in terms of thickness, etc. The only thing is that I'm struggling to get someone to supply me with these. Maybe try Fensport?
MR2Mania
Post by MR2Mania »
Really? I thought I just rambled on about nothing in particular? ;)
Less of the old, mate (OK, you're right, my hands are up!) :D
I've been working hard lately, so haven't had much chance to come on here. But I hope to spend a bit more time on here now...
Dean
Post by Dean »
the car is a rev 2 if that makes any difference? :?
i know that gts-chris sells HG so would the 1.2 one he sells be the one for me?
cheerz
dean
MR2Mania
Post by MR2Mania »
Dean wrote:the car is a rev 2 if that makes any difference? :?
cheerz
dean
I think Chris sells the Cometic HGs? That's what some Evo owners use. I don't know what the quality is like for the 3SGTE, as I've not seen one, but then again, when I examined the quality of the good Toyota or TTE ones, I didn't need to look any further.
Dean
Post by Dean »
forgive my ignorance, but you seem to rate the TTE so where do i get one of them
cheerz
dean
p.s gotta sort it asap :(
MR2Mania
Post by MR2Mania »
Dean wrote:forgive my ignorance, but you seem to rate the TTE so where do i get one of them
cheerz
dean
Nothing to forgive, mate. The TTE (Toyota Team Europe, ie the former WRC Rally Team, now the F1 team) ones have been proven on the WRC Celica engines, so at least you know they can be relied upon. I'm trying to get them myself, but in the meantime, why not try Fensport?
Dean
Post by Dean »
thought fensport charged a packet?
cheerz
dean
MR2Mania
Post by MR2Mania »
Dean wrote:thought fensport charged a packet?
cheerz
dean
The TTE ST185 1.2mm gasket should be around £100-110, ISTR. OK, it's more than the stock ST205/Rev3 HG (about £30-35?), but it's bolt on fitment for a Rev1/2. Incidentally, get your head checked to ensure it's not cracked or warped. When fitting a metal gasket of any type, the sealing surfaces of the components you're trying to mate should be perfect.
Dean
Post by Dean »
thanks for your help mate, dont wanna fit it for me to :lol:
i'll try fensport on monday then, thanks again
cheerz
dean
MR2Mania
Post by MR2Mania »
Dean wrote:thanks for your help mate, dont wanna fit it for me to :lol:
LOL. No thanks, Dean! :)
Expect a biggish bill to have the work done. I've heard of a few people that have had to pay in excess of £1k for all the work to be done, although to be fair, some had the cambelt done at the same time. It's not a cheap job for most. :(
Dean
Post by Dean »
:shock: :( :evil:
