How to re-torque ARP studs after engine break-in to prevent Head gasket failure.
[url=https://www.imoc.co.uk/app.php/kb/viewarticle?a=147&sid=bba26d0805b8ec60487671659445a28b]Knowledge Base - How to re-torque ARP studs after engine break-in to prevent Head gasket failure.[/url]
I've noticed over the years that MR2 enthusiasts do not take the time to re torque their ARP studs after engine break-in.
During the break-in period, the engine heat cycles, there are many vibrations that move things around, and other things that move the studs in the block.
Here's what you do to keep this from happening:
1) Remove the valve cover.
2) Refer to the factory torque sequence
3) Break loose the first nut from the stud using a breaker bar.
4) Remove the nut completely.
5) Use an Allen key socket
6) Make sure the nut is cleaned, and liberally apply ARP moly lube
7) Torque the nut down to 65 ft lbs.
9) Repeat steps 3-8 in the correct torque sequence until you have done them all.
10) Clean the valve cover gasket mating surface with carb cleaner or brake cleaner.
11) Apply a dab of Toyota FIPG
12) Secure the valve cover with bolts or Allen key bolts using the factory grommets and you're good.
I hope this helps folks with rebuilt engines.
Originally posted by No Shoes
Always follow ARP instruction's on torque specs and procedures.
Torque it down as normal in sequence to 60ft/lbs, then gradually loosen off in sequence of removal, then torque to 60ft/lbs again, repeating until your torque it for the 5th time.
This was discussed in length between
Hello Graeme,
Good question.
times, the threads of the bolt or nut are seating in to the threads they
are going into.
takes place the friction between the two pieces is reduced giving you
more torque applied to clamping load vs overcoming friction.
times the effects are minimal.
done again during assembly.
keep the nuts with the studs, matched sets.
to go but most don't want to spend the time.
working for you.
Typically we recommend a head re torque after a period of time.
not due to stud stretch but normally to head gasket compression and
everything moving around a bit after running.
of gasket.
is needed in the instructions.
mistakes so it is a good double check.
back the nuts off, one at a time, about 1/4~1/2 turn and then pull right
back to full torque.
gasket from shifting.
If you have any additional questions please contact me.
Regards,
Kev
