I've done some searching and found some vague information on getting this part used from a breaker.
i read in one place that the part is standard across 80's toyotas, and then that it can be found on any japanese car.
can it be found on non-toyota cars? what ages of cars should i be looking for? 20 quid from toyota seems a little steep.
Coolant Expansion Tank Cap
- Lauren
- IMOC Committee
Re: Coolant Expansion Tank Cap
You can use the corolla one. The problem you have is that because yours has perished so have many others, so it might be hard to find a good one. That said it can be done.
Thought they are around £15 from MrT? the new ones are made in a rubbery type plastic which is obviously going to fair better than the original somewhat brittle cap.
i called toyota and the price they gave me was between 19 and 20. can't remember the exact number. i figure i will get a new one eventually, but having just bought the car and having the MOT up in a few weeks (and having moved to the UK from Canada in september) i'd rather spend as little as possible at the moment. i'm really struggling...
