[Mk2] [Turbo] help AP Power fc
Goto page 1, 2, 3  Next
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK2 1990 - 1999 NA & Turbo -> Modifications
Author Message
lelo1982
PostPosted: Fri Jan 11, 2008 5:40 pm    Post subject: [Mk2] [Turbo] help AP Power fc Reply with quote Reply with quote including images
hi all
i write from italy and I hope that someone of can help me to you.
I have mr2 Turbo America and i have a AP Power fc.
The problem is that after I have installed it and swap wires to match a rev2 JDM wiring harness, the car don't start.
I have also disarmed teh boost control byt it doesn't want to start
please help me
Back to top
User is offline
Rory
1996 Toyota MR2 Mk2 Turbo Rev3
PostPosted: Fri Jan 11, 2008 6:28 pm    Post subject: Reply with quote Reply with quote including images
Have you tried starting without the hand commander attached?
Back to top
User is offline
lelo1982
PostPosted: Fri Jan 11, 2008 6:39 pm    Post subject: Reply with quote Reply with quote including images
yes, but equally it doesn't start
Back to top
User is offline
Rory
PostPosted: Fri Jan 11, 2008 6:55 pm    Post subject: Reply with quote Reply with quote including images
What fault finding have you done? Is there a spark? Is there fuel?
Back to top
User is offline
lelo1982
PostPosted: Fri Jan 11, 2008 7:08 pm    Post subject: Reply with quote Reply with quote including images
there are both fuel and spark
Back to top
User is offline
tubby_tony
PostPosted: Fri Jan 11, 2008 9:05 pm    Post subject: Reply with quote Reply with quote including images
Is the Power FC the correct version for your car? Have you just installed it or was it already running and you have changed something else in the whole combustion system?
Back to top
User is offline
lelo1982
PostPosted: Fri Jan 11, 2008 9:37 pm    Post subject: Reply with quote Reply with quote including images
excuse me for my bad English
i believe that it is the corredt version, i could show to you some photos, this way you can tell me if it is the correct version. no, I have not changed anything.
would you know me to help?
Back to top
User is offline
mark239
PostPosted: Fri Jan 11, 2008 9:44 pm    Post subject: Reply with quote Reply with quote including images
does it try to spark? Have you fouled the plugs
Back to top
User is offline
lelo1982
PostPosted: Sat Jan 12, 2008 12:26 am    Post subject: Reply with quote Reply with quote including images
I have not understood , please please explained better
I don't speak English a lot of good
Back to top
User is offline
rameairo
PostPosted: Sat Jan 12, 2008 6:32 am    Post subject: Reply with quote Reply with quote including images
Is your PFC serial sw21 or is it sw20?? That is the difference about gen2 and gen3. If it's sw21 that should work ok now after your wire swap if it's done right. If it's sw20 you should look under search button... Then you should do lots of another things as well(change igniter, map,few sensor and injectors), and do some wiring swap again.
Back to top
User is offline
lelo1982
PostPosted: Sat Jan 12, 2008 10:08 am    Post subject: Reply with quote Reply with quote including images
[img]
[/img]
i believe it is sw20 and i have done right wire swap.
thing precisely I have to still do? [/i]
Back to top
User is offline
rameairo
PostPosted: Sat Jan 12, 2008 12:16 pm    Post subject: Reply with quote Reply with quote including images
this should be the right one.. AP Engineering sw20 should work. Do you have righ ECU wire pin layout? And is this that PFC which needs those sensors?
Back to top
User is offline
lelo1982
PostPosted: Sat Jan 12, 2008 1:05 pm    Post subject: Reply with quote Reply with quote including images
yes i have.
I think of him. I have installed a air temperature sensor(89424-42010) to the place of cold start injector
Back to top
User is offline
lelo1982
PostPosted: Sat Jan 12, 2008 6:18 pm    Post subject: Reply with quote Reply with quote including images
upppp
Back to top
User is offline
lelo1982
PostPosted: Sun Jan 13, 2008 2:54 pm    Post subject: Reply with quote Reply with quote including images
uppp
Back to top
User is offline
rameairo
PostPosted: Sun Jan 13, 2008 4:06 pm    Post subject: Reply with quote Reply with quote including images
Can someone tell me why US tubby's need those sensor's? I didn't install anything on my JDM MR2. Just plug and start.
Back to top
User is offline
jimGTS
Premium Member
1997 Toyota MR2 Mk2 Turbo Rev4
PostPosted: Mon Jan 14, 2008 2:21 pm    Post subject: Reply with quote Reply with quote including images
you dont and shouldnt need any sensor to swap....
IF however you want to ditch the AFM and run on a map based setup, then you will need to wire in the AIT and MAT sensor (Cold start sensor for manifold temp, and ait for intake/induction temp) into the ecu, (thats all), ditch the AFM, fit a rev3 map sensor, then you should be good to use the other (rev3) MAP sensor option from the hand commander.....
this is why the ap is generally werth more, because you can convert and still use the same ecu and ditch the afm....
if you try on a rev3 type apexi fc, only difference to the above is youll need to get a rev3 ignitor and rewire the ecu (and preferably fit larger injectors)...
i would check your wiring....
(not that i wired my own, so i wouldnt be able to help with the specifics)
Back to top
User is offline
lelo1982
PostPosted: Mon Jan 14, 2008 3:38 pm    Post subject: Reply with quote Reply with quote including images
[img]
i swap wires following this diagram
USA GEN 2 1991 in to JDM GEN 2 1993[/img]
Back to top
User is offline
lelo1982
PostPosted: Tue Jan 15, 2008 3:15 pm    Post subject: Reply with quote Reply with quote including images
upp [Sad]
Back to top
User is offline
JMR_AW11
1989 Toyota MR2 Mk1b
PostPosted: Thu Jan 17, 2008 10:48 pm    Post subject: Reply with quote Reply with quote including images
lelo1982 wrote:
upp [Sad]
Have you tried a standard JDM ECU in place of the APFC?
If you do this you can read the Toyota fault codes that could tell you if the wiring is wrong.
Back to top
User is offline
Display posts from previous:
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK2 1990 - 1999 NA & Turbo -> Modifications All times are GMT
Page 1 of 3
Jump to:
