[Mk2] [Turbo] AP Apexi Power FC for GEN. 2 3-SGTE "1991-1993" (AP SW21 Model)
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK2 1990 - 1999 NA & Turbo -> Modifications
Author Message
myblackstar
Guest
PostPosted: Fri Aug 31, 2007 12:56 am    Post subject: [Mk2] [Turbo] AP Apexi Power FC for GEN. 2 3-SGTE "1991-1993" (AP SW21 Model) Reply with quote Reply with quote including images
hi, guys i was wondering if any of you guys could help me out by let me know which pin on the AP Apexi Power FC for GEN. 2 3-SGTE (AP SW21 Model) controls the Intake Air temp Sensor ... . This model was created by AP for the MR2 SW20 Chassi (1990-1993)....I am unable to located a pin diagram for the AP Apexi Power FC models online......Well, i hope someone on this forum is able to help me out...thanks guys....
Back to top
Ryan.g
PostPosted: Sat Sep 01, 2007 10:45 am    Post subject: Reply with quote Reply with quote including images
This is how you need to wire the MAT and AIT on ap engineering setup
To save wiring in new wires you can connect the AIT sensor into the brown and black wires in the afm wiring.
HTH
Back to top
User is offline
myblackstar
Guest
PostPosted: Sat Sep 01, 2007 4:18 pm    Post subject: Thank you for the info... Reply with quote Reply with quote including images
Hey, thanks for helping me out...i am so glad i have you guys in this forum and the GT4OC.NET too really good info.
Back to top
Scott Barton
PostPosted: Sat Sep 01, 2007 5:26 pm    Post subject: Reply with quote Reply with quote including images
Moving to Modifications.
Back to top
User is offline
bryan@berktechnology.com
Guest
PostPosted: Thu Sep 20, 2007 9:31 am    Post subject: Reply with quote Reply with quote including images
You'll need a few things to run this properly.
1. Wiring diagram that 2BarTuning posted, you'll need to move a few wires. But make sure you know which model 3SGTE you are wiring to. There are two Gen 2 harnesses out there. An early model & late model Gen 2.
Here in the states we only had a 91-92, and then a 93-95. You guys have a 90-91 Gen 2 early model, 92-93 Gen 2 late model, then 94-up (Gen 3).
2. OEM Gen 3 AIT sensor & harness.
3. Cold start mounting plate (Get it at GTS Chris).
4. Apexi MAP sensor & harenss. You should also be able to use a Gen 3 MAP sensor.
Hope that helps...
Back to top
jimGTS
Premium Member
1997 Toyota MR2 Mk2 Turbo Rev4
PostPosted: Thu Sep 20, 2007 1:13 pm    Post subject: Reply with quote Reply with quote including images
you shouldnt need to swap any wires if your running a AP engineering power fc....
this is obviously built for a rev2, or 92 to 93 JDM car..
so in theory if you want this AP PFC, you just need to swap wires to match a rev2 JDM wiring harness.
IF you want to loose the AFM, install an AIT, MAT, MAP senosrs, rev3 ignitor and 540s (optional), youll just need (after youve converted to rev2 JDM), splice the wires for the AIT and MAT as per 2BAR tuning diagram.....
IF you have a rev3/gen3 PFC, youll need to rewire the ecu to a rev3 JDM layout, and connect the MAT and AIT as per 2BAR pic again, but you will need the 540s...
Back to top
User is offline
myblackstar
Guest
PostPosted: Thu Sep 20, 2007 4:45 pm    Post subject: Reply with quote Reply with quote including images
hey, guys: the info. was great: i got everything working see the car been dyno at xsengineering ... .
http://video.cardomain.com/clip.aspx?key=245A52DE9E98AEFB
Back to top
rameairo
PostPosted: Fri Nov 09, 2007 12:37 pm    Post subject: Reply with quote Reply with quote including images
I was found one used PFC for turbo mr2. Now I want to be sure that this is for my rev2. It was attached in rev1 mr2 with wires. [Confused]
Here is identifications:
Serial number: PFC SW21 9807-0003
Inside I found couple numbers
electric plate or what it could call has number FC3-A 05984-L5001-00
and a chip FC3-sw21-2
If someone knows what box I have I would be very happy if you could tell me. Even if this is for rev3.
Back to top
User is offline
Display posts from previous:
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK2 1990 - 1999 NA & Turbo -> Modifications All times are GMT
Page 1 of 1
Jump to:
