Hi Ya'll,
The Aerial on my 1994 MR2 goes only part of the way down, segments seem to be sticking?
Tried wd40 and a bit of persuation while it's going up and down but it doesn't seem to help.
Can any of you?
Thanks guys/gals
Aerial doesn't retract fully!?!?!
Re: Aerial doesn't retract fully!?!?!
the aerial has nylon teeth on the mast that go round a cog wound by the motor.. The nylon teeth are probably chewed up... You don't need a whole aerial motor assembly just the mast itself. Its not a terrible job to install yourself, web instructions are about somewhere.
aerial on ebay
Item number: 4542555570 its of an h reg, check it out!!!!
