Starting problems
Carlos
Starting problems
Post by Carlos »
I have an electrical gremlin somewhere... Sometimes when I go to start the car nothing happens. The orange engine light and the battery light dont come on. After clicking the key back and fourth a couple of times everything lights up and the car then starts fine. Has anyone experienced this before? Is there a way to fix it?
Oh, and one more thing. Normally when I start the car form cold something clicks in the engine bay and drains all the power for a few seconds, causing the car to struggle not to stall. I'm guessing the starter motor might be staying on a bit too long, is this a sign that I'm gonna need a new starter soon, or is this likely to be another electrical gremlin?
I hate electrics!! ](*,)
Thanks in advance
Carl
nutter
Re: Starting problems
Post by nutter »
I know this is probably a daft suggestion but have you checked the connections are secure on the battery? I had a problem similar to this and it ended up being a lose postive connector.
HTH
axisofunity
Post by axisofunity »
Carlos wrote:I have an electrical gremlin somewhere... Sometimes when I go to start the car nothing happens. The orange engine light and the battery light dont come on. After clicking the key back and fourth a couple of times everything lights up and the car then starts fine. Has anyone experienced this before? Is there a way to fix it?
Thanks in advance
Have you possibly checked the immobilizer? Sometimes they play up... Don't think it's anything to do with your last problem...
Carl
Carlos
Post by Carlos »
Good thinking, it was the immobilisor. I put some more keys on the key ring last week and i think they were blocking the little sender thingy. As i dont do anything with it, i completely forget its there!
Cheers!! =D>
axisofunity
Carlos wrote:Good thinking, it was the immobilisor. I put some more keys on the key ring last week and i think they were blocking the little sender thingy. As i dont do anything with it, i completely forget its there!
Cheers!! =D>
OMG, I solved a problem :)
Return to “Electrical”
