[Mk2] [Turbo] Best Vernier Pully setting
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK2 -> Modifications
Author Message
rmarr1980
1991 Toyota MR2 Mk2 Turbo Rev1
PostPosted: Sat Dec 16, 2006 12:06 am    Post subject: [Mk2] [Turbo] Best Vernier Pully setting Reply with quote Reply with quote including images
Hi I just bought some Hks vernier pulleys and wandered if anyone knows what the best timing degree advance or retard?
If anyone has a set fitted what setting are they one and how far off was your ignition timing etc?
Back to top
User is offline
tops
1994 Toyota Celica
PostPosted: Sat Dec 16, 2006 4:47 pm    Post subject: Reply with quote Reply with quote including images
i found a guide setting from hks which said they had found 2 degrees advance on inlet and 8 degrees retard on exhaust, might need some fine tuning but should get you started.
Back to top
User is offline
rmarr1980
PostPosted: Sat Dec 16, 2006 5:51 pm    Post subject: Reply with quote Reply with quote including images
Nice one mate saves some time on constant adjustment then run the car then adjust then run then (You know how it is).
Back to top
User is offline
greeny
1989 Toyota MR2 Mk2 Turbo Rev1
PostPosted: Sat Dec 16, 2006 6:40 pm    Post subject: Reply with quote Reply with quote including images
what cams are you using? [Confused]
Back to top
User is offline
RyanRs
PostPosted: Sat Dec 16, 2006 9:12 pm    Post subject: Reply with quote Reply with quote including images
make sure you turn it over by hand before you start the car each time! knock a valve and youll know about it!
Back to top
User is offline
rmarr1980
PostPosted: Sun Dec 17, 2006 8:37 pm    Post subject: Reply with quote Reply with quote including images
Just using standard cams at the mo but may upgarde later to some hks lumpys later!!
Back to top
User is offline
greeny
PostPosted: Mon Dec 18, 2006 11:32 am    Post subject: Reply with quote Reply with quote including images
Then I wouldn't bother mate till your ready to put some cams in IMO.
Its alot of work for minimal gains IIRC, unless youve already got them on.
Michael.
Back to top
User is offline
Century Motorsport
IMOC Affiliated Company
PostPosted: Mon Dec 18, 2006 1:02 pm    Post subject: Reply with quote Reply with quote including images
Michael.
Yeah i agree. When you do get a set of HKS cams they will give you a recommended cam timing figure for each cam. I have found, as so have a few others i've spoke to that a couple more degrees (Between 2 - 4) advance from the reccomended ex cam setting picks up the spool and gives it more top end - but beware the idle is more lumpy with the ex cam advanced.
_________________
World's quickest MR2 specialist - 9.722 @ 148 MPH ----- 07947883103 ---- www.centurymotorsport.com
Back to top
User is offline
rmarr1980
PostPosted: Mon Dec 18, 2006 7:31 pm    Post subject: Reply with quote Reply with quote including images
How much do you guys reckon I could get a set of cams for? Doesn't have to be hks but as long as they are a reputable make and will be worth it?
I dont fancy having to mess about too often with the timing so may aswell do the job lot and now is the best time as I have the engine in bits to do a bit of a rebuild!
Back to top
User is offline
greeny
PostPosted: Mon Dec 18, 2006 11:42 pm    Post subject: Reply with quote Reply with quote including images
www.nengun.com is quite good on prices.
obviously you'll have to re-shim for the new cams.
have a search there should be loads of info on here about the hks cams and also on www.mr2oc.com
Michael.
Back to top
User is offline
rmarr1980
PostPosted: Sun Dec 24, 2006 2:03 am    Post subject: Reply with quote Reply with quote including images
Hey just been researching the hks cams and am really stuck they offer 256, 264 and 272 degree cam durations how do i know whats gonna be the best to go for?
cheers
Back to top
User is offline
Century Motorsport
PostPosted: Sun Dec 24, 2006 10:33 am    Post subject: Reply with quote Reply with quote including images
what turbo are you using or planning on using??
That wil give you a good guideline on what cams your after.
Back to top
User is offline
rmarr1980
PostPosted: Sun Dec 24, 2006 12:22 pm    Post subject: Reply with quote Reply with quote including images
Just got a standard ct26 in but had been advised to go for a gt2860rs unit so may go with that if I'm gonna get a better response from the right cams (I want the car to have a good low to mid range power so the turbo needs to spool up quick).
thanks
Back to top
User is offline
TBDevelopments
Guest
PostPosted: Sun Dec 24, 2006 3:10 pm    Post subject: Reply with quote Reply with quote including images
i don't know the guys overseas found some good power increases by playing with the standard cam timing, i believe the retard on the exhaust seriously helps, sound similar to the hks settings you've got.
If you've got them might as well fit them, not hard to install and set up. be good to see the actual gains before fitting some larger units.
The GT2860rs is also best suited to the standard VE's of the standard head and cam's so playing with standard cam timing would make the most of that turbo and head set up. You don't need huge cams etc for this turbo as they usually do more harm than good on small fast responce turbo's
Tim
xxxx
Back to top
Harry
PostPosted: Sun Dec 24, 2006 11:15 pm    Post subject: A1 Reply with quote Reply with quote including images
Tim
xxxx
That is really good information Tim [thumleft]
Back to top
User is offline
Display posts from previous:
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK2 -> Modifications All times are GMT
Page 1 of 1
Jump to:
