rev1-2 turbo engine harness
terminater2_uk
Post by terminater2_uk »
Hiya first time here.
Could anybody tell me if the rev 1 and 2 turbo ecu and wiring harnesses are the same or different?
Recently fitted a rev 2 engine to my rev 1 turbo and need to know whether my ecu and harness will be ok or whether I need the rev 2 versions.
Any help greatly appreciated :)
Mark Edwards
Re: rev1-2 turbo engine harness
Post by Mark Edwards »
I know the ecu's are pinned differently so you can't use a rev1 harness on a rev2 ecu and vise versa. not sure if the rev1 gear will run a rev2 engine though. I'd guess at yes as AFAIK all the bits it connects to are the same.
terminater2_uk
Thanks, much appreciated. Its been wired up with the rev 1 loom by the previous owner but although the starter spins, the engine wont start. Thats why I wondered maybe something was missing.
JJ
Post by JJ »
The engines and electronics are the same on both revisions. The ecu and wiring loom are different !
If you want to save yourself some hardship and if you've a rev 2 engine loom, get a rev 2 ecu plugged in. Working a rev 1 ecu to a rev 2 loom won't work.. niether vice versa. Theres a 21 pin difference in the two ecus .. not worth repinning.
So either pull the old loom off your rev 2 engine and swap it out for the rev 1 or simply buy the rev 2 ecu !
Take you about 3 hrs to change it out in situ ! :shock:
I have one for sale by the way !! :wink:
Mark Edwards
JJ wrote:I have one for sale by the way !! :wink:
Hint hint! :lol:
terminater2_uk
Well what I think he's done is when he got the engine, the loom had been chopped for easy removal. So what the plank has done is chop his rev 1 loom and tried to join it to the rev 2 loom.
I think I can safely say I need a rev 2 ecu and loom if anybodys got both. How much? :)
terminater2_uk
Can anyone tell me what revision my engine and ecu is please? I think its a rev 1 ecu and rev 2 engine but I'm not sure
JJ
Post by JJ »
Its a rev 2 engine ! But the ecus a rev 1 !!
Save the hassle and try and source a rev 2 engine loom and ecu.
I'll have a look around !! I definitely have the ecu, but no loom - well I've got a hacked up one but wouldn't sell that to anyone as it gave me crap.
Fonzy
Post by Fonzy »
ok im gonna give you some advice which at this point you dont want to hear but give it 6 months with a working rev2 turbo engine you will be glad you heard! Buy a rev3 loom and ecu! install this as it will give you much much more tuning ability, i appreciate at this point you just want a working engine but you are going to the hassle of stripping the loom and ecu so add one thats worth it. i think there are 1 or 2 other peices you need but im sure cost wise it wont be massively different, although your car will be a different animal altogether!
Think about it, get some more advice, think about it some more, then do it! in 6 months to a year you will be gutted you if you dont!
terminater2_uk
Problem is I dont really know what I'm doing so I want the easiest option. Just something I can plug straight in without having to change anything.
JJ
Post by JJ »
Whereabouts are you chap ??
terminater2_uk
Pontypool South Wales
JJ
Post by JJ »
Blimey,
pitty you we'rent closer, I'd have it running in 2 hours ! :D
terminater2_uk
:( Had a look at it today, theres plugs cut ogg, wires cut and taped up, its totally butchered :(
Need to find a rev 1 loom for next weekend desperately
Return to “Electrical”
