Speedo prob
samoli
Speedo prob
Post by samoli »
Hi
recently bought a Mk2 N/A 1993.
ive got a prob with my speedo. :( it reads a higher speed than im actually doing.
the guy before me replaced the clocks for reasons i dont know, and he has replaced the fascias.
my trip goes up to fast!
somy mileage is going up quickly.
but the only thing i can think he has done is put a kph clock on from an import and put a mph fascia on, which would make sense.
is there a more serious issue or does this sound correct??
the speedo is on the left and rev counter on the right.
cheers
Jon S
Re: Speedo prob
Post by Jon S »
A kmh dial face would go up to 180. Does yours?
samoli
Re: Speedo prob
Post by samoli »
only 160
Jon S
Re: Speedo prob
Post by Jon S »
It sounds to me as if you've got an import that hasn't been de-limited (i.e. is still reading in kmh) and the dials have been changed to mph. However, I'm assuming that you've got a UK model. :scratch:
I'm not an expert, but I have changed my dial faces and fitted a delimiter (mine's an import).
I suspect my speedo needle doesn't read correctly (I've not been done for speeding so it can't be that far out). *touch wood*
I'm pretty sure my milometer is right though.
Unless someone else can come up with a solution, I'd recommend taking it to a garage to be re-calibrated.
Jon
Return to “Electrical”
