Electric mirrors and wing mirror retract
pegsy
Post by pegsy »
Hi every1,
I've just registered to this site and already after reading throough a few forums i've found it really helpful. But there is one thing i'm slightly stuck with. Currently the right wing mirror isn't retracting and also the electric mirrors have stopped working. I've only had the car about 6 months and it's worked perfectly up untill the window regulator snapped. I had this fitted but i'm beginning to to think has damp got into the control panel on the door?
Everything else seems to be working ie, windows, central locking etc and this has now become a pain.
Has anyone else experieneced the same problem or if nopt can anyone help?
cheers in advance
pegsy
bristol
:x
User avatar
Driftlimits Performance
IMOC Affiliated Company
Re: Electric mirrors and wing mirror retract
hmmmm.
I can still move my mirrors with the direction jobby but for some reason they just stopped folding :(
Have no clue why. sorry!
lower
Post by lower »
the wiring harnesses can fail where they flex at the door hinge over time. i noticed my wing mirrors would only fold occasionaly and then stopped althogether. then the central locking started becoming erratic. replacing the door wiring harness solved the problem.
User avatar
Ah cool. I'll have a looky at the weekend.
Cheers :D
samoli
Post by samoli »
are retracting mirrors an optional extra, if not then mine dont work either. :(
Leon.
Post by Leon. »
samoli wrote:are retracting mirrors an optional extra, if not then mine dont work either. :(
UK cars don't generally have folding mirrors, yes they are an extra.
However, most imports do have folding mirrors.
You should have a switch near your window and mirror controls (on drivers side) so it should be obvious if you have that option or not.........
HTH
Frustrated Pilot
Post by Frustrated Pilot »
my sterio has failed for the same reason :( :cry:
philz
Post by philz »
Skywalker wrote:hmmmm.
Mine do the same. I've checked fuses and they're fine, there's also voltage at the back of the switch when I try to retract so the switch is ok. Dunno what it is that's stopping them working now :?
User avatar
Could be the relay under the bonnet. I still need to check mine..
Hurstie1981
Post by Hurstie1981 »
Take off the door card, and make sure that the connector block is connected properly to the door switch. There are two connectors coming off the switch, the one that controlls the mirrors came loose on mine, took me ages to work out why....doh!! #-o
Return to “Electrical”
