MOT emissions testing - CAT/no CAT
Goto page Previous  1, 2, 3, 4  Next
Author Message
Marf
1996 Mazda RX-7
PostPosted: Wed Feb 16, 2011 12:57 pm    Post subject: Reply with quote Reply with quote including images
toxo wrote:
Just had mine done again.
Rev3 turbo, fresh head rebuild. Always run on Tesco 99.
CO: 0.36%
HC: 64ppm
Decatted J?
Back to top
User is offline
toxo
PostPosted: Wed Feb 16, 2011 2:18 pm    Post subject: Reply with quote Reply with quote including images
CO: 0.36%
HC: 64ppm
Decatted J?
Of course!
_________________
Back to top
User is offline
Marf
1996 Mazda RX-7
PostPosted: Wed Feb 16, 2011 2:22 pm    Post subject: Reply with quote Reply with quote including images
Interesting Mr Bond [Think]
I think I'll book mine in for a pre-emptive emissions test and see what's what.
Back to top
User is offline
toxo
PostPosted: Wed Feb 16, 2011 2:23 pm    Post subject: Reply with quote Reply with quote including images
I bet you can't get it lower than that [Laughing]
Back to top
User is offline
Marf
1996 Mazda RX-7
PostPosted: Wed Feb 16, 2011 2:24 pm    Post subject: Reply with quote Reply with quote including images
Watch this space [Razz]
Back to top
User is offline
Gazza_DJ
Premium Member
1997 Toyota MR2 Mk2 NA Rev4
PostPosted: Sun Aug 14, 2011 10:54 pm    Post subject: Reply with quote Reply with quote including images
My NA failed emissions with a decat.
Back to top
User is offline
raptor95GTS
PostPosted: Mon Aug 15, 2011 12:06 pm    Post subject: Reply with quote Reply with quote including images
a 97 is the lower of the emissions levels so harder to pass without a CAT
Back to top
User is offline
Gazza_DJ
Premium Member
PostPosted: Mon Aug 15, 2011 2:12 pm    Post subject: Reply with quote Reply with quote including images
Indeed - Lambda and idle readings were fine, it was just the fast engine speed readings it failed on.
Back to top
User is offline
toxo
PostPosted: Mon Aug 15, 2011 2:15 pm    Post subject: Reply with quote Reply with quote including images
Do you have the figures to hand?
Back to top
User is offline
Gazza_DJ
Premium Member
PostPosted: Mon Aug 15, 2011 2:33 pm    Post subject: Reply with quote Reply with quote including images
The certificate is still in the car, I'll post the figures later this evening after I've picked the missus up from the station.
Back to top
User is offline
Gazza_DJ
Premium Member
PostPosted: Mon Aug 15, 2011 4:56 pm    Post subject: Reply with quote Reply with quote including images
1st Fast idle:
CO: 0.925
HC: 82
Lambda: 0.985
2nd Fast idle:
CO: 0.694
HC: 48
Lambda: 1.008
Idle:
CO: 0.439
Back to top
User is offline
dylan5084
Premium Member
PostPosted: Fri May 22, 2015 4:21 pm    Post subject: Re: MOT emissions testing - CAT/no CAT Reply with quote Reply with quote including images
nathan smith wrote:
mot garages now use the 13th edition ehaust standards book. if vehicle being tested is not in the book,then tester must use default limits,these are basicaly not cat limits (pre 92)eg.mr2 turbos are not in this book
Just had mine mot'd and this is exactly the case [thumleft]
Back to top
User is offline
Peter Gidden - SBITS
IMOC Affiliated Company
2002 Noble M500
PostPosted: Fri May 22, 2015 4:48 pm    Post subject: Re: MOT emissions testing - CAT/no CAT Reply with quote Reply with quote including images
Correct. A MR2 Turbo with decat in normal, healthy condition will nearly always record a CO of 0.7-1%. Anything substantially more e.g. above 1.3%, and whilst it will pass the MOT, suggests a problem with the engine or management system.
_________________
Engine Builder to Simon Hicks - 555bhp 532ftlbs
Brighton National Speed Trials Class Winner 2011
Brighton National Speed Trials Class Winner 2010
Brighton National Speed Trials Class Record Holder 2010 on
Back to top
User is offline
dylan5084
Premium Member
PostPosted: Fri May 22, 2015 4:51 pm    Post subject: Re: MOT emissions testing - CAT/no CAT Reply with quote Reply with quote including images
Mine just passed with 2.6% what do I need to do now, I've just changed the lambda sensor, do I need another ecu?
Back to top
User is offline
2002 Noble M500
PostPosted: Fri May 22, 2015 7:32 pm    Post subject: Re: MOT emissions testing - CAT/no CAT Reply with quote Reply with quote including images
Highly unlikely.
Back to top
User is offline
dylan5084
Premium Member
PostPosted: Fri May 22, 2015 7:34 pm    Post subject: Re: MOT emissions testing - CAT/no CAT Reply with quote Reply with quote including images
Highly unlikely.
I've changed everything else
Back to top
User is offline
Davsurfa
PostPosted: Sat May 23, 2015 3:46 pm    Post subject: Reply with quote Reply with quote including images
My 94 n/a went in for mot, the tester said because it didn't come with a cat it didn't need one. I still bought one to weld on to original system, just in case I needed it, put it in for test with the japspeed. When I picked it up he just said "All passed, emissions weren't a problem" but I didn't get an emissions sheet with my test cert. Not entirely sure how that worked but I have an mot cert [Cool]
Back to top
User is offline
Gazza_DJ
Premium Member
PostPosted: Wed Aug 12, 2015 12:02 pm    Post subject: Reply with quote Reply with quote including images
My latest. Rev5 NA, stock cat.
Back to top
User is offline
2002 Noble M500
PostPosted: Wed Aug 12, 2015 12:27 pm    Post subject: Reply with quote Reply with quote including images
It will have had a cat fitted when new.
Back to top
User is offline
Davsurfa
PostPosted: Thu Aug 13, 2015 9:31 am    Post subject: Reply with quote Reply with quote including images
I should of said mines a G-Limited import
Back to top
User is offline
Display posts from previous:
Page 2 of 4
Jump to:
