My money pit
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> Member Profiles -> Project Cars
Author Message
Andy F
PostPosted: Mon May 01, 2006 3:36 pm    Post subject: My money pit Reply with quote Reply with quote including images
First i got myself a rev1 NA, got it chipped but always fancied a turbo, so i went over to MRD in Liverpool in Feb 02, he had a stockish rev5 turbo in purple, i really wanted it, but it was 16k the other car he had was a GOLD rev2 with all the body kit on, so i had a go in it...wow i had to have it i wasn't botherd about the kit it just felt great.
Later i found i was running stock boost (204flywheel), but had a MBC so i took the car to Well lane and they upped the boost to about 1 bar, think this made 260bhp. The bug had bitten, next i got a HKS intercooler, back on the dyno and 281bhp lovely [Smile] thats when we found out the car had a Farina racing ecu fitted and a hybrid CT26, so we pushed it further and finally got 337bhp, not bad for a rev2 in 2002.
I then had a go at drag racing i managed 13.06, not brilliant but not bad at the time.
Next i started looking at bigger turbo's and all the stuff needed to go with them, so i went for it 15k loan and i started ordering.I wasn't to sure what i was getting, there wasn't many people doing it then, so wasted loads of money really.
Extreme boost GT30 kit, this was a good buy.
Tec3 ECU, this was a bad buy, no one to map it really.
Soon all my bits turned up, so i went to the guy that was going to build it....he was busy and behind schedule, i waited 6 months, he was still behind. I then met Dino who put me on to Ian Ashton, so i picked all my bits up and took them to Ians.
2 months later we fired the engine up, things were great so i drove the car home so i could get some miles on it before mapping started.
A couple of days later i took the car out of the garage and left it to warm up on the drive then i started to hear a nasty ticking noise, i switched the car off straight away. The oil pump pulley had worked loose and come off so the entire engine had been starved!!
We changed the bearings and cleaned the cams up, then Thor had a go at mapping and the car made 408 @hubs... not bad but the engine let go a few months later.
Engine # 2
I was able to use injectors and things like that again but the block, head, pistons crank, cams and even my TTE rods were ruined.
I started again, currant list bits
GT30 turbo
Piper 272 cams
Group A manifold, Tial wastgate
Group A Charge cooler
Chris K long rod with CP pistons
Rev1/2 block
Rev3 head
HKS fuel rail and FPR with 1000cc top feeds
Tilton carbon carbon clutch
Motec M4
At this speck the car made about 400 flywheel at Tuning Japanese, but the cams were not dialled in propley,at the moment the car is with Dave Rowe at Motec UK getting the cams set up spot on then a final map. I think 450 RWH should be quite easy, but not as easy as the US guys get it...........
Back to top
User is offline
matt_mr2t
2001 BMW 3 Series
PostPosted: Thu May 04, 2006 9:11 am    Post subject: Reply with quote Reply with quote including images
Any reason why the engine let go ?
Back to top
User is offline
Andy F
PostPosted: Thu May 04, 2006 11:59 am    Post subject: Reply with quote Reply with quote including images
The engine was never the same after the oil pump pulley came loose, cams were scored, also i now think we replaced the big end bearings with the wrong ones.
Reving it to 8k at Elvington sealed its fate [Mr. Green]
Back to top
User is offline
Andy F
PostPosted: Mon May 22, 2006 7:22 pm    Post subject: Reply with quote Reply with quote including images
A few more picys....
This is the first engine build
Second engine, build with more reliable parts.
Alloy alternator and engine mount bracket [Wink]
This is the TTE charge cooler
And this is how it doesn't line up when you use a GT30 and a Group A manifold
Back to top
User is offline
TBDevelopments
Guest
PostPosted: Fri Jun 09, 2006 8:19 pm    Post subject: Reply with quote Reply with quote including images
how did you get over the step in the intake pipes from the st205 cc and the gt30? the outlet pipe on the gt30 isn't that far off the ct20b and being used on a gen 3 head and manifold i can't see why they don't line up that well.
Any pics?
Tim
xxxx
Back to top
Andy F
PostPosted: Fri Jun 09, 2006 8:31 pm    Post subject: Reply with quote Reply with quote including images
Hi Tim
The manifold is the Group A jobby, and the turbo mounts futher over to the front of the engine,,,also the CC is a Group A 185!
To get round it i had the CC inlet cut off and and piece the same diametre as the turbo outlet welded on at a weird angle.
Not the best picture to see it
Back to top
User is offline
TBDevelopments
Guest
PostPosted: Fri Jun 09, 2006 8:33 pm    Post subject: Reply with quote Reply with quote including images
hello buddy.
Hope your well.
Ah just wandered. So technically if your using a st205 CC and a turbo using a gen 3 turbo manifold you shouldn't get the same problem.
Tim
xxxx
Back to top
Andy F
PostPosted: Fri Jun 09, 2006 8:43 pm    Post subject: Reply with quote Reply with quote including images
xxxx wrote:
hello buddy.
Hope your well.
Tim
xxxx
I don't think so mate [Confused] but the bigger turbos will be getting very close to the clutch bleeder thing!
Back to top
User is offline
TBDevelopments
Guest
PostPosted: Fri Jun 09, 2006 8:46 pm    Post subject: Reply with quote Reply with quote including images
yeah you have real problems mounting anything larger than a t3 size intake housing. but i'm using a gt2860rs which fits fine [Smile]
This is also why i'm running tubular manifolds for the larger kits i'm doing, this will move the turbo's over slightly to the same place as the gen 1/2's and remove that problem.
Tim
xxxx
Back to top
Andy F
PostPosted: Fri Jun 09, 2006 9:13 pm    Post subject: Reply with quote Reply with quote including images
You seem to have it hand Tim [Very Happy]
Back to top
User is offline
TBDevelopments
Guest
PostPosted: Fri Jun 09, 2006 9:15 pm    Post subject: Reply with quote Reply with quote including images
hey can't say i don't do my homework [Smile]
You still got my stickers on the car [Wink] or they fall of at some point
Tim
xxxx
Back to top
Andy F
PostPosted: Fri Jun 09, 2006 9:21 pm    Post subject: Reply with quote Reply with quote including images
1 is still on mate, take a look at the picture of the car from the rear (1st picy) i think, where the 16 valve turbo should be [Mr. Green]
Back to top
User is offline
TBDevelopments
Guest
PostPosted: Fri Jun 09, 2006 9:27 pm    Post subject: Reply with quote Reply with quote including images
yeah i remember when you sent me the pics when you fitted them. I just wandered if they were still on [Smile]
If you want any nice ones for the side windows let me know [Wink]
Tim
xxxx
Back to top
Andy F
PostPosted: Fri Jun 09, 2006 9:31 pm    Post subject: Reply with quote Reply with quote including images
If your coming up to TOTB, just bring some up and stick em on the car.....oh and a free turbo of corse [clown]
Back to top
User is offline
TBDevelopments
Guest
PostPosted: Fri Jun 09, 2006 9:33 pm    Post subject: Reply with quote Reply with quote including images
if you don't mind keeping them on the car i'll send some over to you. Get them done a custom colour for you if you want.
I've always said if i can help you out with something to give me a shout [Smile]
Tim
xxxx
Back to top
Andy F
PostPosted: Fri Jun 09, 2006 9:38 pm    Post subject: Reply with quote Reply with quote including images
Tim
xxxx
Cool...go for it [Very Happy]
Back to top
User is offline
TBDevelopments
Guest
PostPosted: Fri Jun 09, 2006 9:40 pm    Post subject: Reply with quote Reply with quote including images
ok buddy.
What colour do you want?
If you send me a colour sample i can get them done in that colour if you want.
Tim
xxxx
Back to top
Century Motorsport
IMOC Affiliated Trader
PostPosted: Sat Jun 10, 2006 5:20 pm    Post subject: Reply with quote Reply with quote including images
Hi mate, i see you had an HKS i/c. How did you find this unit and did you alter the i/c pipes at all??
At what stage did you decide that that i/c wasnt up to it and went for the cc??
Thanks,
Nathan
p.s nice engine build mate [Dancing]
Back to top
User is offline
Andy F
PostPosted: Sun Jun 11, 2006 9:45 am    Post subject: Reply with quote Reply with quote including images
Thanks,
Nathan
Hi Nathan
The HKS did well on my standard engine, it was only when i did the 1st rebuild that i swapped it. The IC pipes were in a stupid place, as most seem to be (running over the top of the exhaust manifold) i heat wrapped it to help a little.
I would go CC at any stage of engine tune, consistency of power as opposed to fits and spurts!
BTW
I bought the HKS IC, i didn't find it [clown] [Mr. Green]
Cheers fella
Back to top
User is offline
TheRoadWarrior
PostPosted: Sun Jan 27, 2008 6:13 pm    Post subject: Reply with quote Reply with quote including images
Andy, where did you get the alloy alternator bracket, or was it custom made? This must save a ton of weight!
Back to top
User is offline
Display posts from previous:
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> Member Profiles -> Project Cars All times are GMT
Page 1 of 1
Jump to:
