[Mk2] [Turbo] How to set static timing?
Author Message
msherry21
PostPosted: Wed Mar 07, 2018 1:37 pm    Post subject: [Mk2] [Turbo] How to set static timing? Reply with quote Reply with quote including images
Hi all,
Recently I replaced my distributor as it had cracked and the timing was way out!
How do I make sure the static timing is set properly before setting the ignition timing?
Cheers, Michael.
Back to top
User is offline
mr2magic
1991 Toyota MR2 Mk2 Turbo Rev1
PostPosted: Wed Mar 07, 2018 2:29 pm    Post subject: Reply with quote Reply with quote including images
Static timing is set primarily using the crank and cam pulleys. On the outside most lip of the crank pulley there is a vertical slot. This is the #1 cylinder tdc mark. This should be lined up with the '0' line on the lower timing belt cover. Now to make sure you're at tdc on the compression stroke you need to line up the timing marks on the cam pulleys. Each pulley has spokes and on one of these spokes there is a small dimple. The dimple needs to line up with a vertical indent on the cam pulley backing plate. If all these marks line up at the same time your static timing is set correctly (assuming the cam pulleys haven't been rotated!)
If you think the cam pulleys may have been rotated, you need to remove the valve cover and check the alignment of the cam. To do this the cams have a match mark at the pulley end which lines up with a corresponding mark in the bearing cap on the head. Pics of all marks attached:
Crank match mark
Cam pulley match mark
Cam match mark
Back to top
User is offline
msherry21
PostPosted: Wed Mar 07, 2018 2:40 pm    Post subject: Reply with quote Reply with quote including images
Thanks! Thatís exactly what I needed. Iíll check all those and then set my ignition timing.
Thanks again, Michael.
Back to top
User is offline
Gazza_DJ
Premium Member
1997 Toyota MR2 Mk2 NA Rev4
PostPosted: Wed Mar 07, 2018 6:20 pm    Post subject: Reply with quote Reply with quote including images
A fellow member found out recently that later engines may not have the matchmarks on the cam itself, just FYI. His is a 1996/1997.
Back to top
User is offline
androo007
PostPosted: Wed Mar 07, 2018 7:18 pm    Post subject: Reply with quote Reply with quote including images
What an excellent, helpful post! First time I've truly understood it, thank you.
Back to top
User is offline
Display posts from previous:
Page 1 of 1
Jump to:
