Fog light switch bulb
simpson_eh
Post by simpson_eh »
Does anyone know the voltage ie 6v 50ma that I need or can point me in the direction of what bulbs I need to replace the ones in the actual rear fog light switch or can I convert to miniature led
Any help much appreciated
abovetherim
Re: Fog light switch bulb
Post by abovetherim »
I used a suitably sized 12v miniature bulb from maplin.
You have to unwind the legs to remove the old one and fitting is the reverse.
simpson_eh
any ideas if i could bung a mini led in so dont have to worry and will be brighter ?
