Need some help...
I bought stock stereo(tape/cd double din) but it has no plugs and some one before me cut the original plugs and did a mess with the wiring. I am trying to go back to stock so I need two thing:
1. Electrical diagram for original wiring(tape/cd)
2. Where I can get plugs(ebay no luck)
any help greatly appreciated.
OEM Stereo wiring ??
Re: OEM Stereo wiring ??
http://www.imoc.co.uk/forums/kb.php?mode=article&k=125
Best option for the plug would be to check your loom for colours of wires and match them to the page i linked to. Then contact anyone breaking a two and see if they will cut you off the plug with some tails so you can just join em.
You could try mr2 ben, drift limits, woodsport etc or just have a look on that bay of E for a breaker.
But be warned there was an active system and one without the amps also so plugs and wiring colours may differ slightly from different models. Also note that the wiring for the electric aerial may have been messed with as the power for it runs through one of the amps behind the side trim on the passenger side.
