[Mk2] [Turbo] cylinder head removal? such a thing as drop in cams?
Author Message
jimGTS
Premium Member
1997 Toyota MR2 Mk2 Turbo Rev4
PostPosted: Fri Jan 19, 2018 11:57 am    Post subject: [Mk2] [Turbo] cylinder head removal? such a thing as drop in cams? Reply with quote Reply with quote including images
ok, im uprating to ARP head studs and renewing the HG along with a service of the head.
obviously makes sense to change cambelt at the same time.
question is, as long as things are TDC, ok to just remove the top of the belt to be able to get the head off, then worry about the rest of the belt later?
drop in cams;
updated cams always require degreeing? or anything available to literally drop in, reshim and use straight up and bolt to oem cam gears?
Back to top
User is offline
markstevieandmads
PostPosted: Fri Jan 19, 2018 4:12 pm    Post subject: Reply with quote Reply with quote including images
I always thought you had done a writeup on a hg swap?
To answer your first question, i just took the top of the belt off mine and the head came off ok.
Out of interest, why are you taking the head off? If its all fine i wouldnt mess with it.
Back to top
User is offline
jimGTS
Premium Member
PostPosted: Fri Jan 19, 2018 4:21 pm    Post subject: Reply with quote Reply with quote including images
a long long time ago, and i had help for the cambelt side at that time. [blackeye]
cars pushing a small amount of coolant and im due to do a cambelt change anyways, so thought sod it.
Back to top
User is offline
Gazza_DJ
Premium Member
1997 Toyota MR2 Mk2 NA Rev4
PostPosted: Fri Jan 19, 2018 5:34 pm    Post subject: Reply with quote Reply with quote including images
Are the NA cams a drop in replacement?
Back to top
User is offline
Driftlimits Performance
IMOC Affiliated Company
PostPosted: Fri Jan 19, 2018 7:43 pm    Post subject: Reply with quote Reply with quote including images
If removing the head in situ Id get the crank 90 degrees past tdc. That way all your pistons are in the middle. And you can rotate the cams with no worries. Of course I know they are non interference but for that extra peace of mind.
_________________
www.DriftlimitsPerformance.co.uk
info@driftlimitsperformance.co.uk
Back to top
User is offline
C35Rob
Premium Member
1996 Toyota MR2 Mk2 Turbo Rev3
PostPosted: Sat Jan 20, 2018 10:43 pm    Post subject: Reply with quote Reply with quote including images
I have a Rev 3 NA inlet cam in the garage should you be interested, they are 12 degrees longer duration (252 vs 240) and 1.1mm more lift (9.8 vs 8.7) than a stock Rev 3 turbo inlet cam
Slide in the DM's if you're interested
_________________
Back to top
User is offline
markstevieandmads
PostPosted: Sun Jan 21, 2018 9:07 am    Post subject: Reply with quote Reply with quote including images
Mmmm
Im having my rev 2 turbo head refurbished and checked and wonder if the rev 3 na inlet cam is a worth while upgrade?
Back to top
User is offline
Display posts from previous:
Page 1 of 1
Jump to:
