gear change slighlty off
simpson_eh
Post by simpson_eh »
HI all
quick question when changing 1st to 2nd gear is fine but going to third it seams to be slightly off to the right but always goes in, have just changed the cable(left hand one that slots on not screws in) but still doing it
any ideas?? the bushes are good
cheers all
abovetherim
Re: gear change slighlty off
Post by abovetherim »
I assume you have looked closely at the brass middle of the bushes as these do wear and go ovoid. They should fit snugly on the shaft of the linkage of the gearbox. The bearing upgrade is well worth doing here.
If as you say the bushes in the cables are good then next thing to look at is the brass cube under one of the levers of the linkage on the gearbox. Again these can wear significantly causing slop in the linkage and resulting in an imprecise shift. The fix is to rotate the bush 90 deg to run on the other 2 sides.
Sorry I don't have pics but i'm sure a quick google search will bring up some.
simpson_eh
i checked the bush even moved it over from the other cable its the standard bush and nice tight fit, il have a look at the cube as i have heard about that before
pbmr2
Post by pbmr2 »
the turbo and NA cables are different, so I assume you replaced the correct cable.
the brass cube in between the 2 levers on the gearbox, as mentioned above, wear a lot. simply take the upper arm off and rotate the cube so the 2 unworn sides are now the touching side. refit the upper lever.
the stock bushes might look ok but they go very soft over time. BRD Brooks racing development on FB, do some lovely poly bush replacements. cheap too.
simpson_eh
ive looked but cant fathom how to get to the cube lol sounds stupid i know, can it be done from the top?? ive googled and googled it but due to photo*uckit changing their policy everything i look at is missing :(
pbmr2
Post by pbmr2 »
The upper arm has 2 bolts that hold it to the top of the gearbox. just undo them and the upper arm lifts off.
