[Mk2] [Turbo] current recommended clutch kit
Author Message
rossonza
Premium Member
PostPosted: Wed Jan 03, 2018 10:49 am    Post subject: [Mk2] [Turbo] current recommended clutch kit Reply with quote Reply with quote including images
Hi guys/gals.
Anyone have a recommendation on clutch for my rev2 turbo. I'm hoping to at some point run ~300hp.
ive had a look on ebay and most seem to be XTD clutches from the US.
ive looked through older threads and have found the exedy stage 1 being recommended quite a lot. but also the competition clutch stage 4.
Car will be streetdriven, but a weekend car so happy enough to have something slightly stiffer than stock.
Ross. [thumleft]
Back to top
User is offline
markstevieandmads
PostPosted: Wed Jan 03, 2018 5:48 pm    Post subject: Reply with quote Reply with quote including images
same question from me too!
Its a rev 2 also and prob wont reach 300bhp. The current clutch seems ok and looks meaty but as the engine is out, i might as well replace it.
I was thinking a standard oem / exedy clutch?
Back to top
User is offline
Hez
Premium Member
PostPosted: Wed Jan 03, 2018 7:05 pm    Post subject: Reply with quote Reply with quote including images
Just get a standard OEM clutch for anything upto and around 300hp, that way you keep your drivability, a uprated clutch will likely to be snappy and noisy that's from experience. Unless you are planning on tracking it regularly then you won't need to upgrade.
Also, the standard clutch will likely last a lot longer on a street driven car.
Back to top
User is offline
markstevieandmads
PostPosted: Wed Jan 03, 2018 7:09 pm    Post subject: Reply with quote Reply with quote including images
Cheapest i can find is £112.50 and free postage for a complete exedy clutch kit on ebay brand new and same part number as the one tcbparts sell for £126+vat
Think i will be going for that
Back to top
User is offline
Hez
Premium Member
PostPosted: Wed Jan 03, 2018 7:16 pm    Post subject: Reply with quote Reply with quote including images
Just make sure it's a genuine one before you buy.
Back to top
User is offline
Gazza_DJ
Premium Member
1997 Toyota MR2 Mk2 NA Rev4
PostPosted: Wed Jan 03, 2018 8:15 pm    Post subject: Reply with quote Reply with quote including images
And throw away the throwout bearing that comes with it and buy an OEM one.
Back to top
User is offline
Hez
Premium Member
PostPosted: Wed Jan 03, 2018 8:26 pm    Post subject: Reply with quote Reply with quote including images
Funny you should say that gazza, i was going to mention it but thought a OEM one would be ok. I have a ACT HD clutch in mine and fitted that bearing it lasted about 300 miles. Ended up putting a Blueprint OEM one in and its been fine since. The engine builder uses them for most of his cars and has no bother.
All in all as you say probably best to lob it and get a genuine one or a well known OEM .
Back to top
User is offline
Gazza_DJ
Premium Member
PostPosted: Wed Jan 03, 2018 10:16 pm    Post subject: Reply with quote Reply with quote including images
The one that came with my Exedy on my NA went noisy within 5k miles, one on the turbo within about 1k miles. Lesson learned now!
Back to top
User is offline
Al-sw20
1991 Toyota MR2 Mk2 Turbo Rev1
PostPosted: Fri Jan 05, 2018 7:26 pm    Post subject: Reply with quote Reply with quote including images
OEM is fine. Toyota or Exedy.
Just make sure you get a genuine Toyota throwout bearing. You really donít want to have to pull the box in a few miles because the Chinese TOB that came with the clutch fails.
FYI I ran 12.8 @ 110mph with a 1.9 60ft on a OEM clutch at the drag strip.
Back to top
User is offline
markstevieandmads
PostPosted: Fri Jan 05, 2018 8:03 pm    Post subject: Reply with quote Reply with quote including images
Do u mean the clutch release bearing as this is the only bearing for the clutch i can find?
Back to top
User is offline
Al-sw20
PostPosted: Fri Jan 05, 2018 9:30 pm    Post subject: Reply with quote Reply with quote including images
Yeah same thing, called different things in different countries.
A rose by any other name.
Back to top
User is offline
rossonza
Premium Member
PostPosted: Mon Jan 08, 2018 10:05 am    Post subject: Reply with quote Reply with quote including images
can you PM me the link, ill buy an OEM clutch release bearing at the same time. [thumleft]
Back to top
User is offline
CalMac
Premium Member
PostPosted: Mon Jan 08, 2018 2:28 pm    Post subject: Reply with quote Reply with quote including images
Wouldn't recommend the Exedy - it was toast after only a couple of thousand miles on my Rev 3 (maybe 300bhp).
Now running Competition Clutch stage 4 and it's much better and still very driveable [thumleft]
My experience here: http://www.imoc.co.uk/forums/viewtopic.php?p=1665441&sid=f9d6d551d59a762497a6263ddcd9b4dd
Back to top
User is offline
yokomomr4bx
Premium Member
PostPosted: Tue Jan 09, 2018 3:40 pm    Post subject: Reply with quote Reply with quote including images
I fitted an Exedy stage 1 to my rev 3 turbo just under 2 years ago and have since covered about 15,000 miles on it. Mix of alpine driving in crazy cold and crazy heat, city driving stop - start etc, just about any condition the road will put a clutch through. No noises and the bite is still about 10mm from the firewall, same as when I fitted it. That being said, like many drivers on here I'm sure, I never ride the clutch, always in neutral with foot off even if its just for a few seconds. If you were to keep the clutch down for longer than 10 or so seconds I would think your left leg would remind you to put it in neutral [Wink]
EDIT: also running as close to 300 as makes no difference
Back to top
User is offline
Gazza_DJ
Premium Member
PostPosted: Tue Feb 06, 2018 1:49 pm    Post subject: Reply with quote Reply with quote including images
This is on an NA, but same principle... This is why the aftermarket / supplied throw out bearing is rubbish: https://streamable.com/6lf7s
That's not even a year old.
Back to top
User is offline
androo007
PostPosted: Wed Feb 07, 2018 9:42 pm    Post subject: Reply with quote Reply with quote including images
As Gazza says, they all use the same $2 release bearing.
Throw it in the bin and use OEM.
Back to top
User is offline
Display posts from previous:
Page 1 of 1
Jump to:
