Discontinued Parts
MartinF
Discontinued Parts
Post by MartinF »
Would it be useful to have a thread which lists all the parts which are known to be discontinued?
I did have a quick search but couldn't find one.
I found out this week that the gasket between inlet pipe and the throttle body is discontinued. I suppose maybe somebody somewhere may have some on the shelf but asking my local dealer they say discontinued.
To start off:
17376-88380 Inlet Pipe to Throttle Body Gasket
Blue Lexus RCF
Black MKIV UK Manual Supra
Green MK2 MR2 Tin Top
markstevieandmads
Re: Discontinued Parts
Post by markstevieandmads »
Problem is my local dealership say most things are discontinued then i find i can get it elsewhere lol
rev2rich
Post by rev2rich »
HKS SW20 264 Cams unable to get from HKS Japan and Europe. .
kirk
Post by kirk »
MartinF wrote:I found out this week that the gasket between inlet pipe and the throttle body is discontinued. I suppose maybe somebody somewhere may have some on the shelf but asking my local dealer they say discontinued.
What you tend to find, or at least I do anyway, is that most of the original part numbers are discontinued but some have just changed number.
adam3442
Post by adam3442 »
Steering fogs are discontinued, standards are still available.
mr2magic
Post by mr2magic »
might be of help to you guys in this regard...
http://www.mr2forum.de/index.php/Thread ... post864428
MartinF
Post by MartinF »
'Access Denied'
Blue Lexus RCF
mr2magic
Post by mr2magic »
Damn :-( Oh well here goes then...
33481-17011 Gear speedometer, drive (Tachowellenantriebsrad am Differenzial)
11355-74030 Plate rr end no 1 (Halteplatte KW-Simmerring Getriebeseitig)
16268-88382 Pipe water bypass ( Kühlmittelrohre unterm Krümmer)
91611-b1028 Bolt (Schraube)
82661-17110 Cover relay block (untere Abdeckung Sicherungskasten Motorraum)
82661-17181 Cover relay block (obere Abdeckung Sicherungskasten Motorraum)
90980-10354 Housing connector (Steckergehäuse Stecker drittes Bremslicht)
90980-10819 Housing connector (Steckergehäuse Stecker EA1 am Karosse-Kabelbaum zum Sicherungskasten Motorraum)
69005-17111 Cylinder set lock w. power window (Schlosssatz)
68111-17030 Glass sub-assy, front door RH *TT,T 5.0, blue (Seitenscheibe rechts 5% Tönung, blau)
68112-17030 Glass sub-assy, front door LH *TT,T 5.0, blue (Seitenscheibe links 5% Tönung, blau)
77001-17905 Tank Assy, Fuel (Kraftstofftank)
88267-17030 Bracket, Skid Control Computer NO.1 (Halterung, ECU ABS Nr. 1)
88268-17030 Bracket, Skid Control Computer NO.2 (Halterung, ECU ABS Nr. 2)
89541-17010 Computer Assy, Skid Control (ECU ABS)
78024-88382 Bracket Sub-Assy, Accelerator Control Cable (Halterung, Bowdenzug Drosselklappe)
78180-17180 Cable Assy, Accelerator Control (Bowdenzug Drosselklappe)
78180-17210 Cable Assy, Accelerator Control (Bowdenzug Drosselklappe)
78183-17050 Clamp, Accelerator Control Cable (Halteklemme Bowdenzug Drosselklappe)
78113-17020 Cover, Auto Drive Accelerator Link (Abdeckung, Tempomat Umlenkung)
78100-17050 Link Assy, Accelerator (Tempomat Umlenkung)
90249-08116 Pin (For Accelerator Pedal) (Stift Achse, Gaspedal)
78120-17040 Rod Assy, Accelerator Pedal (Gaspedal)
90506-08019 Spring, Tension (For Accelerator Link Rod) Production Date: 01/1990-03/1990 (Zugfeder, Tempomat Umlenkung)
90508-10063 Spring, Torsion (For Accelerator Link) Production Date: 01/1990-03/1990 (Druckfeder, Tempomat Umlenkung)
90959-01399 CLAMP (Schelle)
90201-08076 WASHER, PLATE (Unterlegscheibe)
89170-17010 Sensor Assy, Air Bag (Steuerungseinheit Airbag)
17705-74100 Cap Sub-Assy, Air Cleaner (Abdeckung obere, Luftfiltergehäuse)
17700-74310 Cleaner Assy, Air (Luftfiltereinheit)
17861-88383 Connector, Intake Air NO.2 (Anschluss, Ansaugrohr Nr. 2)
17341-74180 Hose, Air, NO.1 (Schlauch, Luft Nr. 1)
17940-74040 Intercooler Assy (Ladeluftkühler)
22250-74220 Meter Assy, Intake Air Flow (Luftmengenmesser)
17875-74100 Pipe, Intake Air Connector (Verbindungsrohr, Ansaug)
17783-74030 Plate, Air Cleaner Baffle (Halterung LMM an Luftfilter)
53298-17020 Retainer, Cool Air Intake Duct, NO.3 (Halter Ansaugkanal)
17871-88381 Stay, Air Connector (Halterung Drosselklappengehäuse an Zylinderkopf)
17368-88380 Support, Air Tube (Halterung Ansaugrohr "Hotpipe")
17364-88380 Tube, Air, NO.4 (Ansaugrohr "Hotpipe")
90109-06229 BOLT (Schraube)
90540-11012 CUSHION (Gummischeibe)
90560-07024 SPACER (Abstandshalter)
27039-42020 Cover, Alternator Rear End W(POWER STEERING) Production Date: 01/1990-05/1991 Replaced by: 27039-50080 (Hintere Lima Abdeckung)
27039-61250 Cover, Alternator Rear End W(POWER STEERING) Production Date: 10/1991-01/1992 (Hintere Lima Abdeckung)
27039-74170 Cover, Alternator Rear End W(POWER STEERING) Production Date: 05/1991-10/1991 (Hintere Lima Abdeckung)
27357-50030 Holder, Alternator, W/Rectifier W(POWER STEERING) Production Date: 01/1990-05/1991 Replaced by: 27357-50060 (Gleichrichterplatte Lima)
27357-50060 Holder, Alternator, W/Rectifier W(POWER STEERING) Production Date: 05/1991-10/1991 (Gleichrichterplatte Lima)
86300-17100 Antenna Assy, W/Holder MOTOR (Antenneneinheit mit Motor)
86300-17110 Antenna Assy, W/Holder W(REAR SPOILER) (Antenneneinheit mit Motor - wenn Spoiler vorh.)
67625-17040 Bracket, Door Trim, NO.1 LH Location: Passenger Side Production Date: 01/1990-11/1991 (Halteplatte Türgriff Nr. 1)
67626-17030 Bracket, Door Trim, NO.2 RH Location: Passenger Side Production Date: 01/1990-11/1991 (Halteplatte Türgriff Nr. 2)
74633-17010-02 Cap, Coat Hook RED,TRIM3# (Abdeckung Kleiderhaken, rot)
74610-17020-02 Grip Sub-Assy, Assist RED,TRIM3# (Griff, Einstiegshilfe rot)
74814-17010-04 Handle, Front Door Pull, LH DARK BLUE,TRIM8# Location: Driver Side Production Date: 01/1990-09/1991 Replaced by: 74814-17011-R8 (Türgriffschale links blau)
74814-17011-D3 Handle, Front Door Pull, LH RED,TRIM3# Location: Driver Side Production Date: 09/1991-01/1992 (Türgriffschale links rot)
74814-17011-R8 Handle, Front Door Pull, LH DARK BLUE,TRIM8# Location: Driver Side Production Date: 09/1991-11/1993 (Türgriffschale links blau)
74813-17010-04 Handle, Front Door Pull, RH DARK BLUE,TRIM8# Location: Passenger Side Production Date: 01/1990-09/1991 Replaced by: 74813-17011-R8 (Türgriffschale rechts blau)
74813-17011-D3 Handle, Front Door Pull, RH RED,TRIM3# Location: Passenger Side Production Date: 09/1991-01/1992 (Türgriffschale rechts rot)
74813-17011-R8 Handle, Front Door Pull, RH DARK BLUE,TRIM8# Location: Passenger Side Production Date: 09/1991-11/1993 (Türgriffschale rechts blau)
74348-30010-02 Holder, Visor RED,TRIM3# (Halterung Sonnenblende rot)
74348-30010-14 Holder, Visor DARK BLUE,TRIM8# (Halterung Sonnenblende blau)
74631-17020-02 Hook, Coat RED,TRIM3# (Kleiderhaken rot)
74631-17020-04 Hook, Coat DARK BLUE,TRIM8# (Kleiderhaken blau)
74232-17060-02 Panel, Door Armrest Base, LH RED,TRIM3# Location: Driver Side (Armlehne Tür links rot)
74231-17080-02 Panel, Door Armrest Base, RH RED,TRIM3# Location: Passenger Side (Armlehne Tür rechts rot)
74320-17210-01 Visor Assy, LH BLACK,TRIM2# Location: Driver Side (Sonnenblende links schwarz)
74320-17210-02 Visor Assy, LH RED,TRIM3# Location: Driver Side (Sonnenblende links rot)
74320-17210-04 Visor Assy, LH DARK BLUE,TRIM8# Location: Driver Side (Sonnenblende links blau)
74310-17190-01 Visor Assy, RH BLACK,TRIM2# (Sonnenblende rechts schwarz)
74310-17190-02 Visor Assy, RH RED,TRIM3# (Sonnenblende rechts rot)
74310-17190-04 Visor Assy, RH DARK BLUE,TRIM8# (Sonnenblende rechts blau)
74310-17200-01 Visor Assy, RH BLACK,TRIM2# (Sonnenblende rechts schwarz)
74310-17200-02 Visor Assy, RH RED,TRIM3# (Sonnenblende rechts rot)
74310-17200-04 Visor Assy, RH DARK BLUE,TRIM8# (Sonnenblende rechts blau)
74431-17010 Tray, Battery (Batteriefach)
44610-17210 Booster Assy, Brake (Bremskraftverstärker)
44610-17220 Booster Assy, Brake (Bremskraftverstärker)
44758-17060 Bracket, Vacuum Check Valve (Halterung Unterdruckventil Rückschlag)
44758-17070 Bracket, Vacuum Check Valve (Halterung Unterdruckventil Rückschlag)
44776-17030 Hose, Brake Booster (Schlauch Bremskraftverstärker)
44776-17040 Hose, Brake Booster (Schlauch Bremskraftverstärker)
44779-17040 Hose, Union To Connector (Schlauch Verbindung Rohr)
44764-17030 Tube, Connector To Brake Booster (Rohrleitung Verbindung Bremskraftverstärker)
44761-17011 Tube, Intake Manifold Or Vacuum Pump To Connector Production Date: 09/1991-01/1992 (Rohrleitung BKV Ansaugkrümmer)
90461-10744 CLAMP (Schelle)
47264-20040 Clevis, Master Cylinder Push Rod (Schäkel, Hauptbremszylinder)
04493-17050 Cylinder Kit, Brake Master Production Date: 11/1991-01/1992 (Hauptbremszylinder Kit)
47201-17060 Cylinder Sub-Assy, Brake Master (Hauptbremszylinder)
47201-17080 Cylinder Sub-Assy, Brake Master W(*66) (Hauptbremszylinder)
47220-16010 Reservoir Sub-Assy, Brake Master Cylinder (Behälter Bremsflüssigkeit Hauptbremszylinder)
55106-17040 Support Sub-Assy, Brake Pedal (Aufnahme Bremspedal)
44510-17010 Actuator Assy, Brake
44510-17030 Actuator Assy, Brake
44590-17020 Bracket Assy, Brake Actuator
44593-17020 Bracket, Brake Actuator, NO.3
47159-30170 Bracket, Proportioning & By-Pass Valve
44597-17020 Clamp, Brake Actuator Connector, NO.1
47371-30090 Clamp, Brake Tube, NO.1
90541-09076 Cushion(For Brake Actuator Bracket NO.4)
44546-22070 Cushion, Brake Actuator Bolt
44545-22070 Holder, Brake Actuator Bolt
44551-17020 Tube, Brake Actuator, NO.1
44552-17010 Tube, Brake Actuator, NO.2
47311-17100 Tube, Front Brake, NO.1
47311-17130 Tube, Front Brake, NO.1 W(*66)
47312-17020 Tube, Front Brake, NO.2
47312-17040 Tube, Front Brake, NO.2
47313-17080 Tube, Front Brake, NO.3 W(*66)
47321-17100 Tube, Rear Brake, NO.1
47321-17130 Tube, Rear Brake, NO.1 W(*66)
47322-17060 Tube, Rear Brake, NO.2
47322-17080 Tube, Rear Brake, NO.2
47323-17050 Tube, Rear Brake, NO.3 W(*66)
47190-14060 Valve Assy, Proportioning & By-Pass W(*66)
47190-17020 Valve Assy, Proportioning & By-Pass
47190-17040 Valve Assy, Proportioning & By-Pass
47190-17060 Valve Assy, Proportioning & By-Pass W(*66)
90412-10173 Way, NO.1(For Brake Actuator)
90949-01603 CLAMP
93315-15025 SCREW, W/WASHER
90461-06139 Standard Part
13502-88381 Camshaft, NO.2
11285-16011 Plate, Coolant System Caution
11298-74580 Plate, Emission Control Information Production Date: 01/1990-08/1991
11298-74581 Plate, Emission Control Information Production Date: 08/1991-01/1992
11298-74590 Plate, Emission Control Information CALIFORNIA SPEC Production Date: 01/1990-08/1991
11298-74591 Plate, Emission Control Information CALIFORNIA SPEC Production Date: 08/1991-01/1992
17792-74250 Plate, Engine Vacuum Hose Information Production Date: 01/1990-08/1991
17792-74251 Plate, Engine Vacuum Hose Information Production Date: 08/1991-01/1992
11294-74030 Plate, Turbocharger Caution
44391-17010 Label, Power Steering Oil Information
42661-17110 Plate, Tire Pressure Caution
42661-17130 Plate, Tire Pressure Caution
31232-32010 Clip, Release Bearing Hub TYPE 1
31232-32020 Clip, Release Bearing Hub TYPE 2
31232-32030 Clip, Release Bearing Hub TYPE 3
90105-06023 Bolt(For Clutch Release Bearing Hub Retainer)
33102-32011 Cover Sub-Assy, Manual Transmission Case Production Date: 01/1990-04/1990 Replaced by: 33102-32012
33102-32012 Cover Sub-Assy, Manual Transmission Case Production Date: 04/1990-05/1992
33124-32011 Pipe, Oil Receiver, NO.1(MTM) Production Date: 01/1990-05/1990
33124-32012 Pipe, Oil Receiver, NO.1(MTM) Production Date: 05/1990-05/1992
31404-14011 Clevis, Clutch Master Cylinder Push Rod Production Date: 01/1990-08/1991
31404-14012 Clevis, Clutch Master Cylinder Push Rod Production Date: 08/1991-01/1992
31402-17011 Reservoir Sub-Assy, Clutch Master Cylinder
90506-29011 Spring(For Clutch Pedal)
90507-14002 Spring(For Clutch Pedal)
58910-17020-02 Box Assy, Console, Rear RED,TRIM3# Location: Rear
58801-17110-01 Box, Console BLACK,TRIM2# Replaced by: 58801-17110-22
58801-17110-02 Box, Console RED,TRIM3#
58801-17110-04 Box, Console DARK BLUE,TRIM8#
58801-17120-01 Box, Console W(REAR CONSOLE BOX),BLACK,TRIM2# Replaced by: 58801-17120-22
58801-17120-02 Box, Console W(REAR CONSOLE BOX),RED,TRIM3#
58801-17120-04 Box, Console DARK BLUE,TRIM8#
58908-17010-02 Lock Sub-Assy, Console Compartment Door RED,TRIM3#
58908-17010-04 Lock Sub-Assy, Console Compartment Door DARK BLUE,TRIM8#
55716-17020 Brace, Cowl Top To Apron, LH Location: Driver Side
55715-17020 Brace, Cowl Top To Apron, RH Location: Passenger Side
55950-17040 Nozzle Assy, Defroster
55967-17020 Nozzle, Defroster, Lower Location: Lower
55700-17080 Panel Sub-Assy, Cowl
55700-17090 Panel Sub-Assy, Cowl (RADI0 ACOUSTIC FLAVOR)
55718-17020 Panel, Cowl Top Side, Inner LH Location: Inner Driver Side
55717-17020 Panel, Cowl Top Side, Inner RH Location: Inner Passenger Side
55729-17020 Reinforcement, Hood Stopper, LH Location: Driver Side
55728-17020 Reinforcement, Hood Stopper, RH Location: Passenger Side
55739-17020 Stopper, Hood, LH Location: Driver Side
55738-17020 Stopper, Hood, RH Location: Passenger Side
11701-88342-05 Bearing, Crankshaft MARK 5,NO.1,2,4,5 JOURNAL
88200-17060 Actuator Assy, Cruise Control Replaced by: 88200-17070
88291-17030 Bracket, Cruise Control(Auto Drive), NO.1
88292-17030 Bracket, Cruise Control(Auto Drive), NO.2
88240-17140 Computer Assy, Cruise Control
84630-17030 Switch Assy, Cruise Control Main
11401-79455 Block Sub-Assy, Cylinder Production Date: 01/1990-08/1991
12123-88360 Plate, Oil Pan Baffle NO.3
11123-88320 Bush, Exhaust Valve Guide O/S 0.05
11123-88320 Bush, Intake Valve Guide O/S 0.05
11201-88383 Cover Sub-Assy, Cylinder Head Production Date: 01/1990-12/1991 Replaced by: 11201-88385
11201-88385 Cover Sub-Assy, Cylinder Head Production Date: 12/1991-06/1995
11101-88384 Head Sub-Assy, Cylinder Production Date: 01/1990-01/1991 Replaced by: 11101-88391
11101-88386 Head Sub-Assy, Cylinder Production Date: 01/1991-07/1991 Replaced by: 11101-88391
11101-88389 Head Sub-Assy, Cylinder Production Date: 07/1991-08/1991 Replaced by: 11101-88391
11101-88391 Head Sub-Assy, Cylinder Production Date: 08/1991-06/1995
42621-17010 Cap, Wheel
42611-17090-01 Wheel, Disc (For Front) 14X6JJ,TYPE C,BLACK,043 ,202 ,3J6 ,567 ,742 ,8H3
42611-17110 Wheel, Disc (For Front) 14X6JJ,ALUMINUM,TYPE D
42611-17150-01 Wheel, Disc (For Rear) 14X7JJ,TYPE C,BLACK,043 ,202 ,3J6 ,567 ,742 ,8H3
42611-17140 Wheel, Disc (For Spare) 15X4T,TYPE A
19100-88363 Distributor Assy
85720-17030 Motor Assy, Power Window Regulator, Front LH Location: Front Driver Side
89668-17050 Bracket, Engine Control Computer, NO.2
28519-74060 Bracket, Solenoid Resistor
89661-17240 Computer, Engine Control CALIFORNIA SPEC Production Date: 01/1990-09/1990 Replaced by: 89661-17241-84
89661-17241 Computer, Engine Control CALIFORNIA SPEC Production Date: 09/1990-01/1992
89661-17260 Computer, Engine Control Replaced by: 89661-17260-84
89661-17330 Computer, Engine Control Production Date: 01/1990-03/1990 Replaced by: 89661-17332-84
89661-17331 Computer, Engine Control Production Date: 03/1990-01/1991 Replaced by: 89661-17332-84
89661-17332 Computer, Engine Control Production Date: 01/1991-01/1992 Replaced by: 89661-17332-84
28380-74040 Relay Assy, Fuel Pump
28515-74080 Resistor, Solenoid
89420-17040 Sensor Assy, Vacuum (For E.F.I.)
75442-17060-02 Plate, Luggage Compartment Door Name, NO.2 TURBO,SUPER RED 3,3J6 Replaced by: 75442-17060-D0
75442-17060-03 Plate, Luggage Compartment Door Name, NO.2 TURBO,BLUISH GRAY ARGENTUM,187 Replaced by: 75442-17060-17
75442-17060-04 Plate, Luggage Compartment Door Name, NO.2 TURBO,BLUE M,8H3
75442-17060-07 Plate, Luggage Compartment Door Name, NO.2 TURBO,D. TURQUQISE M,742 Replaced by: 75442-17060-G0
75442-17060-08 Plate, Luggage Compartment Door Name, NO.2 TURBO,SUPER WHITE 3,043 Replaced by: 75442-17060-A0
75471-17050-02 Plate, Rear Name MR2,W(PAINTED),SUPER RED 2,3J6
75471-17050-08 Plate, Rear Name MR2,W(PAINTED),SUPER WHITE 3,043
75471-17050-09 Plate, Rear Name MR2,W(PAINTED),SUPER BRIGHT YELLOW,567
75441-17080-03 Plate, Rear Name, No.1 TOYOTA,BLUISH GRAY ARGENTUM,187 Replaced by: 75441-17080-17
75441-17080-04 Plate, Rear Name, No.1 TOYOTA,BLUE M,8H3
75441-17080-07 Plate, Rear Name, No.1 TOYOTA,D. TURQUQISE M,742 Replaced by: 75441-17080-G0
75441-17080-08 Plate, Rear Name, No.1 TOYOTA,SUPER WHITE 3,043 Replaced by: 75441-17080-A0
75441-17080-09 Plate, Rear Name, No.1 TOYOTA,SUPER BRIGHT YELL0W,567 Replaced by: 75441-17080-F0
69365-17020-02 Bezel, Engine Hood Lock Control RED,TRIM3#
53605-17010 Brace Sub-Assy, Rear Suspension, Upper Location: Upper
68810-17060 Hinge Assy, Engine Hood, RH Location: Passenger Side
69350-17040 Lock Assy, Engine Hood
69350-17070 Lock Assy, Engine Hood W(ANTI-THEFT DEVICE)
90508-10034 Spring, Torsion(For Engine Hood Lock Control Lever)
82711-12200 CLAMP, WIRING HARNES
15700-88380 Cooler Assy, Oil
15690-88380 Valve Assy, Oil Cooler Relief
15132-88380 Spring, Oil Pump Relief Valve
25695-88381 Hose(For EGR Vacuum Modulator)
25620-74220 Valve Assy, EGR
64273-17010 Pad, Room Partition, NO.1
64274-17010 Pad, Room Partition, NO.2
58101-17908 Pan Sub-Assy, Front Floor
64206-17090 Panel Sub-Assy, Room Partition
57108-17040 Bracket Sub-Assy, Strut Bar, LH Location: Driver Side
57107-17040 Bracket Sub-Assy, Strut Bar, RH Location: Passenger Side
57103-17010 Crossmember Sub-Assy, Floor, NO.3
57408-17020 Member Sub-Assy, Front Floor Cross
57102-17110 Member Sub-Assy, Front Side, LH Location: Driver Side
57101-17070 Member Sub-Assy, Front Side, RH Location: Passenger Side
57602-17090 Member Sub-Assy, Rear Floor Side, LH Location: Driver Side
57604-17030 Member Sub-Assy, Rear Floor Side, Rear LH Location: Rear Driver Side
57106-17901 Plate Sub-Assy, Front Side Member, LH Location: Driver Side
57105-17901 Plate Sub-Assy, Front Side Member, RH Location: Passenger Side
57192-17040 Plate, Front Side Member, Outer Rear LH Location: Outer Rear Driver Side
57191-17040 Plate, Front Side Member, Outer Rear RH Location: Outer Rear Passenger Side
57632-17020 Reinforcement, Rear Floor Side Member, Front LH Location: Front Driver Side
57631-17020 Reinforcement, Rear Floor Side Member, Front RH Location: Front Passenger Side
90119-08853 BOLT, W/WASHER
48069-17020 Arm Sub-Assy, Front Suspension, Lower NO.1 LH Location: Driver Side
43212-17030 Knuckle, Steering, LH Location: Driver Side
43212-17040 Knuckle, Steering, LH W(*66) Location: Driver Side
43212-17060 Knuckle, Steering, LH W(*66 & POWER STEERING) Location: Driver Side
43211-17030 Knuckle, Steering, RH Location: Passenger Side
43211-17040 Knuckle, Steering, RH W(*66) Location: Passenger Side
43211-17060 Knuckle, Steering, RH W(*66 & POWER STEERING) Location: Passenger Side
52712-17040-02 Moulding, Front Bumper Side, RH SUPER RED 3,3J6 Location: Passenger Side
52712-17040-03 Moulding, Front Bumper Side, RH LIGHT SILVER M.,043 Location: Passenger Side
52712-17040-04 Moulding, Front Bumper Side, RH BLUE,M,8H3 Location: Passenger Side
52712-17040-07 Moulding, Front Bumper Side, RH DARK TURQUOISE MICA,742 Location: Passenger Side Replaced by: 52712-17040-C0
52712-17040-13 Moulding, Front Bumper Side, RH DARK GRAY M,187 ,202 ,567 Location: Passenger Side
52713-17020 Plug, Front Bumper Moulding
52713-17040-02 Plug, Front Bumper Moulding SUPER RED 3,3J6
52713-17040-03 Plug, Front Bumper Moulding LIGHT SILVER M.,043
52713-17040-04 Plug, Front Bumper Moulding BLUE,M,8H3
52713-17040-07 Plug, Front Bumper Moulding DARK TURQUOISE MICA,742 Replaced by: 52713-17040-C0
76863-17020 Retainer, Front Spoiler, Lower NO.2
47750-17080 Cylinder Assy, Disc Brake, LH Location: Driver Side
47750-17090 Cylinder Assy, Disc Brake, LH Location: Driver Side
47730-17090 Cylinder Assy, Front Disc Brake, RH Location: Passenger Side
04947-32090 Fitting Kit, Disc Brake, Front Location: Front
47721-17030 Mounting, Front Disc Brake Cylinder, LH Location: Driver Side
47722-17010 Mounting, Front Disc Brake Cylinder, LH Location: Driver Side
47721-17030 Mounting, Front Disc Brake Cylinder, RH Location: Passenger Side
47721-17040 Mounting, Front Disc Brake Cylinder, RH Location: Passenger Side
47716-17020 Plate, Pad Support, NO.1(For Front Disc Brake)
47716-17020 Plate, Pad Support, NO.2(For Front Disc Brake)
04945-17050 Shim Kit, Anti Squeal, Front Location: Front
47745-17020 Shim, Anti-Squeal, NO.1(For Front Disc Brake)
47745-17030 Shim, Anti-Squeal, NO.1(For Front Disc Brake)
47745-17030 Shim, Anti-Squeal, NO.2(For Front Disc Brake)
47742-17010 Shim, Anti-Squeal, NO.3(For Front Disc Brake)
47742-17020 Shim, Anti-Squeal, NO.3(For Front Disc Brake)
47742-17020 Shim, Anti-Squeal, NO.4(For Front Disc Brake)
69707-17010 Bellcrank Sub-Assy, Door Lock Control, Lower Location: Lower
69220-17030-02 Handle Assy, Front Door Outside, LH SUPER RED 3,3J6 Location: Driver Side
69220-17030-03 Handle Assy, Front Door Outside, LH BLUEISH GRY ARGENTUM,187 Location: Driver Side Replaced by: 69220-17030-17
69220-17030-04 Handle Assy, Front Door Outside, LH BLUE,M,8H3 Location: Driver Side
69220-17030-07 Handle Assy, Front Door Outside, LH DARK TURQUOISE MICA,742 Location: Driver Side
69220-17030-08 Handle Assy, Front Door Outside, LH SUPER WHITE 3,043 Location: Driver Side
69220-17030-09 Handle Assy, Front Door Outside, LH SUPER BRIGHT YELLOW,567 Location: Driver Side
69220-17040-03 Handle Assy, Front Door Outside, LH W(POWER WINDOW),BLUEISH GRY ARGENTUM,187 Location: Driver Side Replaced by: 69220-17030-17
69220-17040-08 Handle Assy, Front Door Outside, LH W(POWER WINDOW),SUPER WHITE 3,043 Location: Driver Side Replaced by: 69220-17030-08
69210-17040-01 Handle Assy, Front Door, Outside RH BLACK,202 Location: Outside Passenger Side Replaced by: 69210-17040-22
69210-17040-02 Handle Assy, Front Door, Outside RH SUPER RED 3,3J6 Location: Outside Passenger Side
69210-17040-03 Handle Assy, Front Door, Outside RH BLUEISH GRY ARGENTUM,187 Location: Outside Passenger Side Replaced by: 69210-17040-17
69210-17040-04 Handle Assy, Front Door, Outside RH BLUE,M,8H3 Location: Outside Passenger Side
69210-17040-07 Handle Assy, Front Door, Outside RH DARK TURQUOISE MICA,742 Location: Outside Passenger Side
69210-17040-08 Handle Assy, Front Door, Outside RH SUPER WHITE 3,043 Location: Outside Passenger Side
69210-17040-09 Handle Assy, Front Door, Outside RH SUPER BRIGHT YELLOW,567 Location: Outside Passenger Side
69206-17030-01 Handle Sub-Assy, Front Door Inside, LH BLACK,TRIM2# Location: Driver Side
69206-17030-02 Handle Sub-Assy, Front Door Inside, LH RED,TRIM3# Location: Driver Side
69206-17030-04 Handle Sub-Assy, Front Door Inside, LH D,BLUE,TRIM8# Location: Driver Side Replaced by: 69206-17030-01
69205-17030-01 Handle Sub-Assy, Front Door Inside, RH BLACK,TRIM2# Location: Passenger Side
69205-17030-02 Handle Sub-Assy, Front Door Inside, RH RED,TRIM3# Location: Passenger Side
69205-17030-04 Handle Sub-Assy, Front Door Inside, RH D,BLUE,TRIM8# Location: Passenger Side Replaced by: 69205-17030-01
69731-17010 Link, Front Door Inside Locking, NO.1 RH Location: Passenger Side
69712-17020 Link, Front Door Lock Remote Control, LH Location: Driver Side
69711-17030 Link, Front Door Lock Remote Control, RH Location: Passenger Side
69040-17091 Lock Assy, Front Door, LH W(ANTI-THEFT DEVICE) Location: Driver Side Replaced by: 69040-17092
69320-17101 Lock Assy, Front Door, LH Location: Driver Side
69030-17061 Lock Assy, Front Door, RH W(POWER WINDOW) Location: Passenger Side
69030-17091 Lock Assy, Front Door, RH W(ANTI-THEFT DEVICE) Location: Passenger Side
69310-17101 Lock Assy, Front Door, RH Location: Passenger Side
69410-17010 Plate Assy, Front Door Lock Striker
67620-17320-01 Board Sub-Assy, Front Door Trim, LH POWER PACKAGE,BLACK,TRIM2# Location: Driver Side
67620-17320-02 Board Sub-Assy, Front Door Trim, LH POWER PACKAGE,RED,TRIM3# Location: Driver Side
67620-17320-04 Board Sub-Assy, Front Door Trim, LH POWER PACKAGE,DARK BLUE,TRIM8# Location: Driver Side
67620-17330-01 Board Sub-Assy, Front Door Trim, LH POWER & LEATHER PACKAGE & W(POWER WINDOW),BLACK,TRIM2# Location: Driver Side
67620-17340-01 Board Sub-Assy, Front Door Trim, LH BLACK,TRIM2# Location: Driver Side
67620-17340-02 Board Sub-Assy, Front Door Trim, LH RED,TRIM3# Location: Driver Side
67620-17340-04 Board Sub-Assy, Front Door Trim, LH DARK BLUE,TRIM8# Location: Driver Side
67620-17360-01 Board Sub-Assy, Front Door Trim, LH LUXURY PACKAGE,BLACK,TRIM2# Location: Driver Side
67620-17360-02 Board Sub-Assy, Front Door Trim, LH RED,TRIM3# Location: Driver Side
67620-17360-04 Board Sub-Assy, Front Door Trim, LH LUXURY PACKAGE,DARK BLUE,TRIM8# Location: Driver Side
67610-17360-01 Board Sub-Assy, Front Door Trim, RH POWER PACKAGE,BLACK,TRIM2# Location: Passenger Side
67610-17360-02 Board Sub-Assy, Front Door Trim, RH POWER PACKAGE,RED,TRIM3# Location: Passenger Side
67610-17360-04 Board Sub-Assy, Front Door Trim, RH POWER PACKAGE,DARK BLUE,TRIM8# Location: Passenger Side
67610-17370-01 Board Sub-Assy, Front Door Trim, RH POWER & LEATHER PACKAGE & W(POWER WINDOW),BLACK,TRIM2# Location: Passenger Side
67610-17390-01 Board Sub-Assy, Front Door Trim, RH BLACK,TRIM2# Location: Passenger Side
67610-17390-02 Board Sub-Assy, Front Door Trim, RH RED,TRIM3# Location: Passenger Side
67610-17390-04 Board Sub-Assy, Front Door Trim, RH DARK BLUE,TRIM8# Location: Passenger Side
90339-10002-12 Cap(For Front Door Trim Board) RED,TRIM3#
67492-17040 Garnish, Front Door Lower Frame Bracket, LH Location: Driver Side
67491-17040 Garnish, Front Door Lower Frame Bracket, RH Location: Passenger Side
67404-17030 Guide Sub-Assy, Front Door Window, Rear LH Location: Rear Driver Side
67403-17030 Guide Sub-Assy, Front Door Window, Rear RH Location: Rear Passenger Side
67112-17030 Panel, Front Door, Outer LH Location: Outer Driver Side
67111-17030 Panel, Front Door, Outer RH Location: Outer Passenger Side
67778-17040-01 Pocket, Front Door Trim, LH BLACK,TRIM2# Location: Driver Side Replaced by: 67778-17040-C1
67778-17040-02 Pocket, Front Door Trim, LH RED,TRIM3# Location: Driver Side
67778-17040-04 Pocket, Front Door Trim, LH DARK BLUE,TRIM8# Location: Driver Side
67780-17030-01 Pocket, Front Door Trim, LH W(POWER WINDOW),BLACK,TRIM2# Location: Driver Side Replaced by: 67780-17030-C0
67780-17030-02 Pocket, Front Door Trim, LH W(POWER WINDOW),RED,TRIM3# Location: Driver Side
67780-17030-04 Pocket, Front Door Trim, LH W(POWER WINDOW),DARK BLUE,TRIM8# Location: Driver Side
67770-17030-01 Pocket, Front Door Trim, RH W(POWER WINDOW),BLACK,TRIM2# Location: Passenger Side
67770-17030-02 Pocket, Front Door Trim, RH W(POWER WINDOW),RED,TRIM3# Location: Passenger Side
67770-17030-04 Pocket, Front Door Trim, RH W(POWER WINDOW),DARK BLUE,TRIM8# Location: Passenger Side
67777-17040-02 Pocket, Front Door Trim, RH RED,TRIM3# Location: Passenger Side
67777-17040-04 Pocket, Front Door Trim, RH DARK BLUE,TRIM8# Location: Passenger Side
68127-17021 Plate, Front Door Glass, Rear RH Location: Rear Passenger Side
69820-17040 Regulator Sub-Assy, Front Door Window, LH Location: Driver Side
69810-17040 Regulator Sub-Assy, Front Door Window, RH Location: Passenger Side
67211-17030 Stop, Front Door Window, Upper MARK 2 Location: Upper
67233-20040 Support, Rear Door Trim MARK 2 Production Date: 01/1990-04/1990 Replaced by: 67233-20041
67233-20041 Support, Rear Door Trim MARK 2 Production Date: 04/1990-11/1993
90119-08012 BOLT, W/WASHER Replaced by: 91651-40812
53701-17050 Apron Sub-Assy, Front Fender, RH Location: Passenger Side
55226-17020 Cover, Dash Panel Front Trim
53788-17020 Gusset, Front Fender Apron, Lower LH Location: Lower Driver Side Production Date: 01/1990-12/1991
53787-17020 Gusset, Front Fender Apron, Lower RH Location: Lower Passenger Side Production Date: 01/1990-12/1991
55210-17040 Insulator Assy, Dash Panel
57302-17030 Member Sub-Assy, Front Luggage Cross
57301-17060 Member Sub-Assy, Steering Gear Box Support Production Date: 01/1990-12/1991 Replaced by: 48824-17030
57301-17070 Member Sub-Assy, Steering Gear Box Support W(ELECTRICAL TYPE POWER STEERING) Replaced by: 48824-17030
57308-17060 Pan Sub-Assy, Front Luggage W(ELECTRICAL TYPE POWER STEERING)
55101-17080 Panel Sub-Assy, Dash
55102-17050 Panel Sub-Assy, Dash, Lower Location: Lower
57307-17060 Panel Sub-Assy, Front Luggage End
53211-17030 Support, Radiator, RH Location: Passenger Side
72760-17020 Adjuster Assy, Lumbar Support, LH Location: Driver Side
72020-17090 Adjuster Sub-Assy, Front Seat, LH LUXURY PACKAGE Location: Driver Side
72020-17100 Adjuster Sub-Assy, Front Seat, LH Location: Driver Side
72010-17110 Adjuster Sub-Assy, Front Seat, RH Location: Passenger Side
71074-17240-01 Cover, Front Seat Back, LH(For Separate Type) BLACK,TRIM2# Location: Driver Side
71074-17240-02 Cover, Front Seat Back, LH(For Separate Type) RED,TRIM3# Location: Driver Side
71074-17240-04 Cover, Front Seat Back, LH(For Separate Type) DARK BLUE,TRIM8# Location: Driver Side
71074-17260-01 Cover, Front Seat Back, LH(For Separate Type) LUXURY PACKAGE OR POWER & LUXURY PACKAGE,BLACK,TRIM2# Location: Driver Side
71074-17260-02 Cover, Front Seat Back, LH(For Separate Type) LUXURY PACKAGE OR POWER & LUXURY PACKAGE,RED,TRIM3# Location: Driver Side
71074-17260-04 Cover, Front Seat Back, LH(For Separate Type) LUXURY PACKAGE OR POWER & LUXURY PACKAGE,DARK BLUE,TRIM8# Location: Driver Side
71074-17280-01 Cover, Front Seat Back, LH(For Separate Type) POWER & LUXURY & LEATHER PACKAGE,BLACK,TRIM2# Location: Driver Side Replaced by: 71074-17282-C1
71073-17240-01 Cover, Front Seat Back, RH(For Separate Type) BLACK,TRIM2# Location: Passenger Side
71073-17240-02 Cover, Front Seat Back, RH(For Separate Type) RED,TRIM3# Location: Passenger Side
71073-17240-04 Cover, Front Seat Back, RH(For Separate Type) DARK BLUE,TRIM8# Location: Passenger Side
71073-17260-01 Cover, Front Seat Back, RH(For Separate Type) LUXURY PACKAGE OR POWER & LUXURY PACKAGE,BLACK,TRIM2# Location: Passenger Side
71073-17260-02 Cover, Front Seat Back, RH(For Separate Type) LUXURY PACKAGE OR POWER & LUXURY PACKAGE,RED,TRIM3# Location: Passenger Side
71073-17260-04 Cover, Front Seat Back, RH(For Separate Type) LUXURY PACKAGE OR POWER & LUXURY PACKAGE,DARK BLUE,TRIM8# Location: Passenger Side
71073-17280-01 Cover, Front Seat Back, RH(For Separate Type) POWER & LUXURY & LEATHER PACKAGE,BLACK,TRIM2# Location: Passenger Side Replaced by: 71073-17282-C1
71072-17180-01 Cover, Front Seat Cushion, LH(For Separate Type) BLACK,TRIM2# Location: Driver Side
71072-17180-02 Cover, Front Seat Cushion, LH(For Separate Type) RED,TRIM3# Location: Driver Side
71072-17180-04 Cover, Front Seat Cushion, LH(For Separate Type) DARK BLUE,TRIM8# Location: Driver Side
71072-17200-01 Cover, Front Seat Cushion, LH(For Separate Type) LUXURY PACKAGE OR POWER & LUXURY PACKAGE,BLACK,TRIM2# Location: Driver Side
71072-17200-02 Cover, Front Seat Cushion, LH(For Separate Type) LUXURY PACKAGE OR POWER & LUXURY PACKAGE,RED,TRIM3# Location: Driver Side
71072-17200-04 Cover, Front Seat Cushion, LH(For Separate Type) LUXURY PACKAGE OR POWER & LUXURY PACKAGE,DARK BLUE,TRIM8# Location: Driver Side
71072-17220-01 Cover, Front Seat Cushion, LH(For Separate Type) POWER & LUXURY & LEATHER PACKAGE,BLACK,TRIM2# Location: Driver Side
71071-17180-01 Cover, Front Seat Cushion, RH(For Separate Type) BLACK,TRIM2# Location: Passenger Side
71071-17180-02 Cover, Front Seat Cushion, RH(For Separate Type) RED,TRIM3# Location: Passenger Side
71071-17180-04 Cover, Front Seat Cushion, RH(For Separate Type) DARK BLUE,TRIM8# Location: Passenger Side
71071-17200-01 Cover, Front Seat Cushion, RH(For Separate Type) LUXURY PACKAGE OR POWER & LUXURY PACKAGE,BLACK,TRIM2# Location: Passenger Side
71071-17200-02 Cover, Front Seat Cushion, RH(For Separate Type) LUXURY PACKAGE OR POWER & LUXURY PACKAGE,RED,TRIM3# Location: Passenger Side
71071-17200-04 Cover, Front Seat Cushion, RH(For Separate Type) LUXURY PACKAGE OR POWER & LUXURY PACKAGE,DARK BLUE,TRIM8# Location: Passenger Side
71071-17220-01 Cover, Front Seat Cushion, RH(For Separate Type) POWER & LUXURY & LEATHER PACKAGE,BLACK,TRIM2# Location: Passenger Side
72128-17010-02 Cover, Seat Track Bracket, Inner Front LH RED,TRIM3# Location: Inner Front Driver Side
72127-17010-02 Cover, Seat Track Bracket, Inner Front RH RED,TRIM3# Location: Inner Front Passenger Side
72127-17010-04 Cover, Seat Track Bracket, Inner Front RH DARK BLUE,TRIM8# Location: Inner Front Passenger Side
72123-17010-02 Cover, Seat Track Bracket, Outer Front RED,TRIM3#
71910-17110-01 Headrest Assy, Front Seat BLACK,TRIM2#
71910-17110-02 Headrest Assy, Front Seat LUXURY PACKAGE OR POWER & LUXURY PACKAGE,RED,TRIM3#
71910-17110-04 Headrest Assy, Front Seat DARK BLUE,TRIM8#
71910-17140-01 Headrest Assy, Front Seat BLACK,TRIM2#
71910-17140-02 Headrest Assy, Front Seat RED,TRIM3#
71910-17140-04 Headrest Assy, Front Seat DARK BLUE,TRIM8#
71506-17070 Pad Sub-Assy, Front Seat Back W/Frame, LH Location: Driver Side
71506-17080 Pad Sub-Assy, Front Seat Back W/Frame, LH LUXURY PACKAGE Location: Driver Side
71505-17070 Pad Sub-Assy, Front Seat Back W/Frame, RH Location: Passenger Side
71553-17020 Pad, Front Seat Back, B
71553-17020 Pad, Front Seat Back, B LUXURY PACKAGE Location: Passenger Side
71553-17010 Pad, Front Seat Back, C LUXURY PACKAGE OR LUXURY & LEATHER PACKAGE
71553-17020 Pad, Front Seat Back, C
71512-17100 Pad, Front Seat Cushion, LH (For Separate Type) Location: Driver Side
71511-17090 Pad, Front Seat Cushion, RH(For Separate Type) Location: Passenger Side
71200-17410-01 Seat Assy, Front LH ***,BLACK,TRIM2# Location: Front Driver Side
71200-17410-02 Seat Assy, Front LH ***,RED,TRIM3# Location: Front Driver Side
71200-17410-04 Seat Assy, Front LH ***,DARK BLUE,TRIM8# Location: Front Driver Side
71200-17450-01 Seat Assy, Front LH ***,LUXURY PACKAGE OR POWER & LUXURY PACKAGE,BLACK,TRIM2# Location: Front Driver Side
71200-17450-02 Seat Assy, Front LH ***,LUXURY PACKAGE OR POWER & LUXURY PACKAGE,RED,TRIM3# Location: Front Driver Side
71200-17450-04 Seat Assy, Front LH ***,LUXURY PACKAGE OR POWER & LUXURY PACKAGE,DARK BLUE,TRIM8# Location: Front Driver Side
71200-17480-01 Seat Assy, Front LH ***,POWER & LUXURY & LEATHER PACKAGE,BLACK,TRIM2# Location: Front Driver Side
71100-17410-01 Seat Assy, Front RH ***,BLACK,TRIM2# Location: Front Passenger Side
71100-17410-02 Seat Assy, Front RH ***,RED,TRIM3# Location: Front Passenger Side
71100-17410-04 Seat Assy, Front RH ***,DARK BLUE,TRIM8# Location: Front Passenger Side
71100-17450-01 Seat Assy, Front RH ***,LUXURY PACKAGE OR POWER & LUXURY PACKAGE,BLACK,TRIM2# Location: Front Passenger Side
71100-17450-02 Seat Assy, Front RH ***,LUXURY PACKAGE OR POWER & LUXURY PACKAGE,RED,TRIM3# Location: Front Passenger Side
71100-17450-04 Seat Assy, Front RH ***,LUXURY PACKAGE OR POWER & LUXURY PACKAGE,DARK BLUE,TRIM8# Location: Front Passenger Side
71100-17480-01 Seat Assy, Front RH ***,POWER & LUXURY & LEATHER PACKAGE,BLACK,TRIM2# Location: Front Passenger Side
71812-17040-02 Shield, Front Seat Cushion, LH RED,TRIM3# Location: Driver Side
71812-17040-04 Shield, Front Seat Cushion, LH DARK BLUE,TRIM8# Location: Driver Side
71811-17040-02 Shield, Front Seat Cushion, RH RED,TRIM3# Location: Passenger Side
71811-17040-04 Shield, Front Seat Cushion, RH DARK BLUE,TRIM8# Location: Passenger Side
71930-17020-02 Support, Front Seat Headrest W(LOCK),RED,TRIM3#
71930-17020-04 Support, Front Seat Headrest W(LOCK),DARK BLUE,TRIM8#
71931-17010-02 Support, Front Seat Headrest W/O(LOCK),RED,TRIM3#
71931-17010-04 Support, Front Seat Headrest W/O(LOCK),DARK BLUE,TRIM8#
72140-17070 Track Assy, Front Seat, Inner LH Location: Inner Driver Side
72130-17100 Track Assy, Front Seat, Inner RH Location: Inner Passenger Side
48811-17050 Bar, Stabilizer, Front Location: Front
48811-17060 Bar, Stabilizer, Front W(POWER STEERING) Location: Front Production Date: 01/1990-03/1990
48811-17070 Bar, Stabilizer, Front W(POWER STEERING) Location: Front Production Date: 03/1990-01/1992
48811-17080 Bar, Stabilizer, Front W(POWER STEERING) Location: Front
48811-17090 Bar, Stabilizer, Front W(POWER STEERING) Location: Front
48824-17030 Bracket, Stabilizer, Front Location: Front Production Date: 10/1991-01/1992
48815-17040 Bush, Front Stabilizer Bar, NO.1 Production Date: 01/1990-03/1990
48815-17080 Bush, Front Stabilizer Bar, NO.1 W(POWER STEERING)
48131-17280 Spring, Front Coil, LH Location: Driver Side Production Date: 03/1990-01/1992
48131-17310 Spring, Front Coil, LH Location: Driver Side
48131-17280 Spring, Front Coil, RH Location: Passenger Side Production Date: 03/1990-01/1992
48131-17310 Spring, Front Coil, RH Location: Passenger Side
48815-17050 Standard Part
45524-10030 Cap, Steering Rack Guide Spring W(POWER STEERING)
44218-12020 Gasket, Valve Housing
44250-17020 Gear Assy, Power Steering(For Rack & Pinion)
45510-17040 Gear Assy, Steering
45516-17020 Grommet, Steering Rack Housing, NO.1
45501-17040 Housing Sub-Assy, Steering Rack
44022-17020 Housing, Control Valve
45196-50010 Label, Steering Shaft Installation Caution
90179-36001 Nut(For Steering Rack Guide Spring Cap)
45541-17030 Pinion, Steering
44204-17020 Rack Sub-Assy, Power Steering
45521-17040 Rack, Steering
44210-17020 Valve Assy, Power Steering Control
44201-17020 Valve Sub-Assy, Power Steering Control
22210-74490 Body Assy, Throttle
23264-74040 Bracket, Fuel Filter
23261-88380 Cover, Injector
23260-79175 Injector Assy, Cold Start Fuel
23814-88382 Pipe Sub-Assy, Fuel Delivery
23801-88381 Pipe Sub-Assy, Fuel, NO.1
23902-88380 Tube Sub-Assy, Fuel
23903-88380 Tube Sub-Assy, Fuel, NO.3
91651-G0832 BOLT, W/WASHER
90461-08680 CLAMP
90079-11038 SCREW, W/WASHER
91611-G0812 Standard Part
77601-17020 Band Sub-Assy, Fuel Tank, NO.1
77035-17060 Cable Sub-Assy, Fuel Lid Lock Control
77740-17020 Canister Assy, Charcoal
77653-17010 Cushion, Fuel Tank, NO.3
77654-17010 Cushion, Fuel Tank, NO.4
77655-17010 Cushion, Fuel Tank, NO.5
77262-17010 Gasket, Fuel Filler Pipe
23271-74250 Hose, Fuel, NO.1(For Return Tube, NO.1)
77350-17020 Lid Assy, Fuel Filler Opening
77264-17030 Tube, Fuel, NO.1(For Charcoal Canister)
90949-01499 CLAMP
33201-32010 Arm, Reverse Shift
33290-32012 Ball Assy, Lock, NO.1
33290-32020 Ball Assy, Lock, NO.2 Production Date: 01/1990-07/1990 Replaced by: 33290-32021
33290-32021 Ball Assy, Lock, NO.2 Production Date: 07/1990-08/1992
90109-18002 Bolt (For Shift Inter Lock Plate)
33240-32020 Bracket Assy, Reverse Shift Arm
33228-32010 Bracket, Reverse Shift Arm
33506-17020 Cover, Control Shaft
33506-17030 Cover, Control Shaft Replaced by: 33506-17070
33212-20060 Fork, Gear Shift, NO.1
33211-32010 Fork, Reverse Shift Production Date: 01/1990-05/1990
33211-32020 Fork, Reverse Shift Production Date: 05/1990-09/1991 Replaced by: 33270-32010
33270-32010 Fork, Reverse Shift Production Date: 09/1991-01/1992
33232-20010 Head, Gear Shift, NO.1
33256-20010 Lever, Select Inner
33251-32031 Lever, Shift, Inner NO.1
33252-32030 Lever, Shift, Inner NO.2
33208-32021 Pin Sub-Assy, Reverse Restrict Production Date: 01/1990-11/1990
33208-32022 Pin Sub-Assy, Reverse Restrict Production Date: 11/1990-08/1992
33223-32010 Pivot, Shift Arm
33206-32022 Plate Sub-Assy, Shift Inter Lock Production Date: 01/1990-11/1990
33206-32023 Plate Sub-Assy, Shift Inter Lock Production Date: 11/1990-08/1992
33266-20010 Plate, Shift Inter Lock
33266-32022 Plate, Shift Inter Lock
33276-20010 Seat, Select Spring, NO.1
33205-20010 Shaft Sub-Assy, Gear Shift Fork, NO.1
33242-32011 Shaft, Gear Shift Fork, NO.1 Production Date: 01/1990-05/1990
33242-32020 Shaft, Gear Shift Fork, NO.1 Production Date: 05/1990-01/1992
33244-20040 Shaft, Gear Shift Fork, NO.3
33261-17030 Shaft, Shift & Select Lever
33261-17040 Shaft, Shift & Select Lever
90501-10048 Spring, Compression(For Reverse Shift Arm Roller)
90501-14092 Spring, Compression, NO.1 (For Select Return) Replaced by: 90501-14129
90501-16102 Spring, Compression, NO.1 (For Select Return)
90501-14135 Spring, Compression, NO.2 (For Select Return)
90501-18068 Spring, Compression, NO.2 (For Select Return)
88444-17020 Bracket, Idle Pulley
88376-17020 Cap, Blind SUCTION
88321-14011 Head, Cooler Compressor Cylinder Location: Front Production Date: 01/1990-06/1990
88321-30300 Head, Cooler Compressor Cylinder Location: Front Production Date: 06/1990-06/1995
88322-32030 Head, Cooler Compressor Cylinder Location: Rear
88403-12030 Hub Sub-Assy, Magnet Clutch
88356-12010 Label, Compressor Caution
88341-14010 Plate Sub-Assy, Valve Location: Front
88342-14010 Plate Sub-Assy, Valve Location: Rear
88344-14011 Reed, Discharge Valve
88343-14011 Reed, Suction Valve
88412-17010 Rotor Sub-Assy, Magnet Clutch
88411-17060 Stator Sub-Assy, Magnet Clutch
88371-17100 Valve, Suction
90099-04255 BOLT, SERVICE VALVE
90099-04968 BOLT, THROUGH
88688-17320 BRACKET, COOLER
90099-13024 KEY Replaced by: 90099-13012
90099-05253 NUT
90099-08058 PIN, STRAIGHT Replaced by: 88328-01010
90099-07127 RING, SNAP (FOR MAGNET CLUTCH)
84998-10310 Cap, Air Conditioner Control Bulb 14V 0.84W
55900-17100 Control Assy, Air Conditioner Production Date: 01/1990-08/1990 Replaced by: 55900-17120
55900-17110 Control Assy, Air Conditioner W(AIR CONDITIONER) Production Date: 01/1990-08/1990 Replaced by: 55900-17130
55900-17120 Control Assy, Air Conditioner Production Date: 08/1990-11/1993
55900-17130 Control Assy, Air Conditioner W(AIR CONDITIONER) Production Date: 08/1990-11/1993
55086-17020 Duct Sub-Assy, Heater To Register, NO.3
87201-17040 Duct, Air, NO.1
55843-17040 Duct, Heater To Register, NO.1
55846-17020 Duct, Heater To Register, NO.4
88578-17080 PACKING, COOLER, NO.
88578-17090 PACKING, COOLER, NO.
88473-17030 Holder, Receiver
88715-17112 Pipe, Cooler Refrigerant Discharge, A Production Date: 11/1991-11/1993
88715-17120 Pipe, Cooler Refrigerant Discharge, B Production Date: 01/1990-03/1990 Replaced by: 88705-17040
88716-17100 Pipe, Cooler Refrigerant Liquid, B
88717-17090 Pipe, Cooler Refrigerant Suction, A
88705-17040 Tube Sub-Assy, Discharge Production Date: 01/1990-03/1990
90099-04431 BOLT, WASHER HEAD
88688-17280 BRACKET, COOLER
88718-17130 CLAMP, PIPING
88718-17140 CLAMP, PIPING
88718-17150 CLAMP, PIPING
88718-17160 CLAMP, PIPING
88718-17170 CLAMP, PIPING
88718-17190 CLAMP, PIPING
88718-17210 CLAMP, PIPING
88718-17230 CLAMP, PIPING
88718-17240 CLAMP, PIPING
88718-17260 CLAMP, PIPING
90480-27004 GROMMET
88714-17090 INSULATOR, PIPING
88714-17110 INSULATOR, PIPING
88714-17011 Standard Part
88714-17100 Standard Part
88716-17170 Standard Part
88650-17120 Amplifier Assy, Cooler Stabilizer
88605-17270 Harness Sub-Assy, Cooler Wiring, NO.1
88648-17030 Harness Sub-Assy, Cooler Wiring, NO.2
88539-17040 Hose, Cooler Unit Drain, NO.1
88510-17140 Unit Assy, Cooler
88688-17340 BRACKET, COOLER
88688-17370 BRACKET, COOLER
88569-17150 CLAMP, COOLER, NO.1
88578-17070 PACKING, COOLER, NO.
88714-10020 PIPE, INSULATOR
88688-17250 Standard Part
87130-17080 Blower Assy, Heater, Front Location: Front
87211-17020 Duct, Air
87150-17240 Radiator Assy, Heater Replaced by: 87150-17241
87106-17120 Servo Sub-Assy, Damper(For Blower)
90099-00181 SCREW
89543-17010 ABS-Sensor vorne links
48815-17100 Bushing Stabilizer
89629-17020 BRACKET, IGNITER ASSY
mr2magic
Post by mr2magic »
No guarantee that you aren't able to find an example of these parts somewhere...but they are officially classed as disco-parts (discontiniued)
simpson_eh
Post by simpson_eh »
lmao almost the whole car
mr2magic
Post by mr2magic »
And that's only what i managed to grab hold of before my access was revoked :-)
MartinF
Post by MartinF »
Oh wow, that is really useful.
Thanks.
Blue Lexus RCF
