Screamer pipe problem...
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK2 1990 - 1999 NA & Turbo
Author Message
caldridge7
1994 Toyota MR2 MK2 GT - T Bar
PostPosted: Mon Sep 25, 2017 7:06 pm    Post subject: Screamer pipe problem... Reply with quote Reply with quote including images
Hi guys I have a t67 greddy turbo and when at max boost the screamer is no where to be heard... Nothing... Why is this??
Back to top
User is offline
shinny
PostPosted: Mon Sep 25, 2017 9:18 pm    Post subject: Reply with quote Reply with quote including images
Turn down the boost then... more screamer [Whistle]
Back to top
User is offline
androo007
Premium Member
PostPosted: Mon Sep 25, 2017 10:38 pm    Post subject: Reply with quote Reply with quote including images
It means the wastegate isn't opening - do you're likely not seeing eno ugh boost to bleed off. What psi are you reading?
Back to top
User is offline
simpson_eh
Premium Member
PostPosted: Mon Sep 25, 2017 11:02 pm    Post subject: Reply with quote Reply with quote including images
Exhaust to loud ? Lol
_________________
Back to top
User is offline
caldridge7
PostPosted: Tue Sep 26, 2017 12:19 pm    Post subject: Reply with quote Reply with quote including images
I get to boost pressure it's about 1.2bar and no when a screamer comes in you can hear it... Mine you cannot... Also does anyone know with hks 272 cams what the kpa should be on idle as mine is 60 kpa on idle but when moving and revving it's absolutely fine... Unsure if there is a bigger problem or its simply the cams....
Back to top
User is offline
simpson_eh
Premium Member
PostPosted: Tue Sep 26, 2017 12:46 pm    Post subject: Reply with quote Reply with quote including images
ive had mine jam open so potentialy jammed closed ?? do you get boost spike ?? with it not bleeding off
Back to top
User is offline
jimGTS
Premium Member
1997 Toyota MR2 Mk2 Turbo Rev4
PostPosted: Tue Sep 26, 2017 1:03 pm    Post subject: Reply with quote Reply with quote including images
mad question, this external wastegate, it is vented to atmos, and not rerouted into the exhaust right?
i would suggest looking at the vac hoses on the wastegate and checking they are plumbed in correctly....
also worth pumping in some air to one of the EW ports to hear it open and close (engine off obviously).
here my tial just for reference
https://www.youtube.com/watch?v=mUQYhcWMkqc
Back to top
User is offline
Display posts from previous:
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK2 1990 - 1999 NA & Turbo All times are GMT
Page 1 of 1
Jump to:
