Heater pipes from hell bypass ( Hose routes)
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK2 1990 - 1999 NA & Turbo
Author Message
SKD
PostPosted: Mon Sep 18, 2017 6:10 pm    Post subject: Heater pipes from hell bypass ( Hose routes) Reply with quote Reply with quote including images
Anyone with aircon manage to route the heater pipe bypass mod successfully below the fuel tank?
I have a Rev 3 Turbo GT and the aircon pipes are making this mod difficult.
There is no room on the LH side of the central fuel tank support.
The heater hose I've bought is 19mm ID with 28mm OD.
I've tried cutting away some of the foam coating around the air con pipe but there is about 16mm of space at best.
I may have to buy some smaller hose with connector reducers and run it through the tight spots .
Any tips?
Thanks [Question] [Question] [Question]
Back to top
User is offline
pbmr2
Premium Member
PostPosted: Tue Sep 19, 2017 2:01 pm    Post subject: Reply with quote Reply with quote including images
take the fuel tank out and go over the top. can take the ripped rigid pipe out at the same time then. it's not that much more work.
Back to top
User is offline
SKD
PostPosted: Mon Oct 30, 2017 12:43 pm    Post subject: Reply with quote Reply with quote including images
Thanks I had a full tank when I did it so did not want to drop it. If there is a job in the future where the tank is dropped I will do it properly then.
In the end there was no room for the bigger hose access all the way to the front.
I had to run both 19mm ID hoses to the handbrake cable and fuel tank central support bracket. I then used 19mm to 13mm barbed hose reducer/connector to allow me to run 13mm ID hoses (20mm OD) to the frunk and connect the same connectors onto the heater hoses in there.
Been running like that for over a month now with no issues. Hopefully this will help any aircon owners with hose routes.
Back to top
User is offline
Display posts from previous:
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK2 1990 - 1999 NA & Turbo All times are GMT
Page 1 of 1
Jump to:
