Gen 2 to Gen 3 3SGE Engine Swap Questions
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK2 1990 - 1999 NA & Turbo
Author Message
dark_uk
PostPosted: Thu Aug 31, 2017 1:17 pm    Post subject: Gen 2 to Gen 3 3SGE Engine Swap Questions Reply with quote Reply with quote including images
Hi All,
My Gen2 3SGE has spun a main bearing and I've grabbed a low mileage Gen3 3SGE and gearbox to replace it.
I've got the engine wiring loom for the Gen3 and and a the old engine and everything else is complete.
Apart from a matching ECU what else do I need for this conversion? Has anyone done it before that has some tips for me?
Cheers! [Very Happy]
Back to top
User is offline
benjo
Premium Member
PostPosted: Thu Aug 31, 2017 2:56 pm    Post subject: Reply with quote Reply with quote including images
Or drop a v6 in from a Camry
_________________
Too weird to live, to rare to die
Back to top
User is offline
pbmr2
Premium Member
PostPosted: Thu Aug 31, 2017 4:08 pm    Post subject: Reply with quote Reply with quote including images
exhaust manifold
will need to re-pin some of the plugs that meet the chassis loom as there are some changes to wiring positions. This is the meat of the swap really.
think the igniter/coil is different
Take this time to do a major service on the new engine.
Back to top
User is offline
dark_uk
PostPosted: Fri Sep 01, 2017 1:55 pm    Post subject: Reply with quote Reply with quote including images
pbmr2 wrote:
exhaust manifold
Ok so I need a suitable exhaust manifold, I guess the downpipe is the same though?
Does anyone know what will need repinning or a diagram of both? I do have the Gen3 loom so perhaps just a gen3 ecu will suffice?
I'll get a timing kit and also sort out the plugs, dizzy, leads, rotor etc.
I have the coil/ignitor for the new engine
Back to top
User is offline
pbmr2
Premium Member
PostPosted: Sat Sep 02, 2017 10:21 am    Post subject: Reply with quote Reply with quote including images
There are guides on the net if you search for them. there isn't really that much to repin but the engine won't work until you do.
You NEED the rev3 ecu, rev2 will not work. careful not to get a later 3sge ecu as they won't work either.
Back to top
User is offline
Display posts from previous:
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK2 1990 - 1999 NA & Turbo All times are GMT
Page 1 of 1
Jump to:
