Manual steering conversion
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK2 1990 - 1999 NA & Turbo
Author Message
pbmr2
Premium Member
PostPosted: Tue Aug 29, 2017 7:55 pm    Post subject: Manual steering conversion Reply with quote Reply with quote including images
Hi,
Have any of you swapped to manual steering from power steering?
Got a rack and column etc and just test fitted it for size. seems simple enough except for the hole in the frunk that isn't big enough for the manual UJ to fit though.
Is the hole in the frunk the only issue?
Any other pointers could be great.
Back to top
User is offline
markstevieandmads
PostPosted: Tue Aug 29, 2017 8:06 pm    Post subject: Reply with quote Reply with quote including images
Hi mate. I was the one you bought it from.
I was told that id need to just enlarge that hole you say and everything else is a straight swap over.
Back to top
User is offline
pbmr2
Premium Member
PostPosted: Tue Aug 29, 2017 9:04 pm    Post subject: Reply with quote Reply with quote including images
yeah measured the columns and manual and PS are the same, just the middle shaft with the UJs differes there.
The manual rack bolts up fine and lines up with that chassis hole, but as you say, it's a little tight [Very Happy]
Going to make a template and mark it out for cutting tomorrow.
all the track rod ends are the same and have fitted new ones. stupidly split one of the boots so going to replace both anyway.
So just the chassis hole? cool, thanks
Back to top
User is offline
Display posts from previous:
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK2 1990 - 1999 NA & Turbo All times are GMT
Page 1 of 1
Jump to:
