Wipers going down into scuttle panel (MK2 Rev1 NA Import)
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK2 1990 - 1999 NA & Turbo
Author Message
Tsukijin-Akiyama
Premium Member
PostPosted: Sat Aug 26, 2017 9:49 pm    Post subject: Wipers going down into scuttle panel (MK2 Rev1 NA Import) Reply with quote Reply with quote including images
Nearly finished my project now, it has it's first MOT in 8 years on monday, and the last thing to do was put in some wiper linkage as someone had converted it to a single one, unfortunately it was broken when I got the car so I bought a normal linkage and fitted it in.
When I turn the wipers on, the arms go straight down into the scuttle panel and get stuck. Tried taking the arms off, running it then replacing the arms in the park position and they do the same thing. Tried setting them higher and they go over the a frame?
Back to top
User is offline
madbasshunter
Premium Member
1991 Toyota MR2
PostPosted: Sun Aug 27, 2017 9:25 am    Post subject: Reply with quote Reply with quote including images
Was the single wiper set to centre park? This is done by moving the position of the arm on the motor so it sounds to me like you need to reposition the arm.
_________________
RyanRs wrote:
Skywalker wrote:
explain how the coolant leaves the expansion tank and goes back into the coolant system?
Seriously , you don't know the answer to this? and you call yourself a car mechanic [Shocked]
Back to top
User is offline
Tsukijin-Akiyama
Premium Member
PostPosted: Sun Aug 27, 2017 10:26 am    Post subject: Reply with quote Reply with quote including images
Not sure if it was set to the centre as I rescued t from a scrap yard by which time it had no arms.
Stupid woman incoming: Is the motor arm inside/under the actual cup for the motor where the magnets are or do you mean something else?
Back to top
User is offline
pbmr2
Premium Member
PostPosted: Mon Aug 28, 2017 10:44 pm    Post subject: Reply with quote Reply with quote including images
There is an arm that spins round on the motor, the while linkage is connected to it. This can be taken off and placed at a different angle. It's held on with a single nut.
Back to top
User is offline
Display posts from previous:
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK2 1990 - 1999 NA & Turbo All times are GMT
Page 1 of 1
Jump to:
