[Mk2] [Turbo] How to tell if Rev 2 or 3 injectors?
Author Message
killerferret666
Premium Member
PostPosted: Mon Aug 21, 2017 1:24 pm    Post subject: [Mk2] [Turbo] How to tell if Rev 2 or 3 injectors? Reply with quote Reply with quote including images
I've removed my rev 2 engine and I didnt know alot about it beforehand. What is the easiest way to confirm it has rev2 injectors and not rev3, do they look different at all?
Im Wanting to confirm because it has a field ECU which can be changed to run the larger injectors so need to make sure that is plug and play on a rev2
_________________
My Blog on Miami GT4 kit car build using MR2 Donor Car
http://miamigt4kitcar.blogspot.co.uk/
twitter for photo's as I'm building -
www.twitter.com/iwanabeaferret
Back to top
User is offline
killerferret666
Premium Member
PostPosted: Tue Aug 22, 2017 5:42 am    Post subject: Reply with quote Reply with quote including images
Bump? Anyone know?
Back to top
User is offline
alanmr2turbo
PostPosted: Wed Aug 23, 2017 12:50 pm    Post subject: Reply with quote Reply with quote including images
Rev2 have black tops and REV3 have Red tops
Back to top
User is offline
killerferret666
Premium Member
PostPosted: Wed Aug 23, 2017 1:38 pm    Post subject: Reply with quote Reply with quote including images
topman, thanks
Back to top
User is offline
jimGTS
Premium Member
1997 Toyota MR2 Mk2 Turbo Rev4
PostPosted: Thu Aug 24, 2017 1:21 pm    Post subject: Reply with quote Reply with quote including images
is this and plug and play ecu? like the mines/blitz?
how is it injector options can be changed out of interest?
Back to top
User is offline
killerferret666
Premium Member
PostPosted: Fri Aug 25, 2017 8:35 am    Post subject: Reply with quote Reply with quote including images
Yes it is like the mines / blitz, but I don't think the option can be changed from what I read, its set when the ECU is programmed back in Japan.
Back to top
User is offline
jimGTS
Premium Member
PostPosted: Fri Aug 25, 2017 9:17 am    Post subject: Reply with quote Reply with quote including images
its what i suspected, hence the interest of how, [blackeye]
Back to top
User is offline
Display posts from previous:
Page 1 of 1
Jump to:
