help please with problem refitting alternator
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK2 1990 - 1999 NA & Turbo
Author Message
drunknmunky
PostPosted: Fri Aug 18, 2017 2:02 pm    Post subject: help please with problem refitting alternator Reply with quote Reply with quote including images
So I'm rejuvenating the mr2 after being parked up for 18 months, alternator had seized so got it out and had it reconditioned. The problem refitting is I can't get the bottom section of the casing into the bracket.
It took some 'gentle persuasion' to get it out, but it appears as if the bracket is about 3mm to narrow. Anybody else had this, or is it common and just takes some more persuasion to refit??
Thanks in advance all.
Back to top
User is offline
mr2garageswindon
1994 Toyota MR2 Mk2 NA Rev3
PostPosted: Fri Aug 18, 2017 2:26 pm    Post subject: Reply with quote Reply with quote including images
Where the bottom bolt goes through there is a movable bush type thing which probably needs a tap with a hammer to make it fit. When doing it back up it moves to take up the clearance to the bracket.
Back to top
User is offline
drunknmunky
PostPosted: Fri Aug 18, 2017 3:12 pm    Post subject: Reply with quote Reply with quote including images
Thankyou so much, I've been swearing at it for it feels like forever!! [Very Happy]
Back to top
User is offline
aussieGT
PostPosted: Fri Aug 18, 2017 3:33 pm    Post subject: Reply with quote Reply with quote including images
I had to take my bracket out and use Thors' hammer to 'tap' mine.
They get a build up corrosion behind the lip, thats what pushes them out making alternators &*%$ to get out and close to impossible to get a new one in.
Drift the xxxxxx out, buy a new bush/collar thing and re-install.
Back to top
User is offline
drunknmunky
PostPosted: Sat Aug 26, 2017 2:24 pm    Post subject: Reply with quote Reply with quote including images
Ok, so having some problems, please help. As soon as I turn the key, the alternator seizes up. I've had it reconditioned so in theory is as good as new.
I install the bracket (3 bolts 2 nuts) then the alternator (2 bolts and tension and plug and earth) so is there something I'm missing. This is getting ridiculous, it's not rocket science but I'm at a complete loss.
Is there anyone local to Nuneaton that wouldn't mind coming to look, maybe try a spare unit in place, that way I would know if the recon is no good.
Please somebody help, I'm ready to throw my spanners away!!
Back to top
User is offline
MartinF
Premium Member
PostPosted: Sun Aug 27, 2017 12:20 pm    Post subject: Reply with quote Reply with quote including images
Did you check it all rotated freely before you fitted it ?
Also when you look down from above are all the pulleys lined up, i.e. the belt is running true. ?
_________________
Blue Lexus RCF
Black MKIV UK Manual Supra
Green MK2 MR2 Tin Top
Back to top
User is offline
drunknmunky
PostPosted: Mon Aug 28, 2017 11:16 am    Post subject: Reply with quote Reply with quote including images
Yep, everything spun free and lined up perfectly, just as soon as I turned it over it locks up.
Back to top
User is offline
MartinF
Premium Member
PostPosted: Mon Aug 28, 2017 11:58 am    Post subject: Reply with quote Reply with quote including images
Weird.
Are you able to provide a picture looking down from above showing the belt and how it is fitting in the pulley between the alternator and crank ?
Back to top
User is offline
drunknmunky
PostPosted: Mon Aug 28, 2017 12:21 pm    Post subject: Reply with quote Reply with quote including images
I don't know how to add images on here to be honest.
Back to top
User is offline
aussieGT
PostPosted: Wed Aug 30, 2017 12:26 am    Post subject: Reply with quote Reply with quote including images
Could you have over tightened the belt in a massive way? That could stop it moving. Maybe.
Back to top
User is offline
drunknmunky
PostPosted: Wed Aug 30, 2017 11:23 am    Post subject: Reply with quote Reply with quote including images
Don't think so, was able to easily put a full half twist into the belt with just a finger and thumb, at the middle point between the two pulleys. Tis what I was always told that would make tension about right.
Back to top
User is offline
drunknmunky
PostPosted: Sat Sep 02, 2017 3:19 pm    Post subject: Reply with quote Reply with quote including images
So finally, it lives again [Very Happy] turns out, there was a small crack in the bottom bolt section of the casing, and when tightening the bolt, it was distorting the housing slightly, just enough to stop it spinning. Of course, as soon as it was undone it would spin again which is why it was so hard to find!
Many thanks to all that tried to help, I'm sure. I'll need more before everything is sorted :-S
Back to top
User is offline
MartinF
Premium Member
PostPosted: Sun Sep 03, 2017 12:28 pm    Post subject: Reply with quote Reply with quote including images
Well done on finding it, was a bit unusual !!
Back to top
User is offline
Display posts from previous:
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK2 1990 - 1999 NA & Turbo All times are GMT
Page 1 of 1
Jump to:
