Stick with 10w40 semi synthetic or can I use 5w40 fully synthetic ?
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK2 1990 - 1999 NA & Turbo
Author Message
mr2_maverick
PostPosted: Fri Aug 18, 2017 1:18 pm    Post subject: Stick with 10w40 semi synthetic or can I use 5w40 fully synthetic ? Reply with quote Reply with quote including images
I am being cheap, I want to use fully synthetic but 10w40 fully synthetic is expensive and harder to find in local shops. So is there anything wrong with using 5w40 fully synthetic? My engine also has a piston slap which goes away once at operating temperature so I would maintain the cold oil thickness. My car is an NA and sees the redline often (of course only at operating temperature). I want to run it on track at some point so I thought fullly synthetic might be better for me. My car already has 10w40 semi in there if that makes a difference. Thanks for your input.
Back to top
User is offline
Gazza_DJ
Premium Member
1997 Toyota MR2 Mk2 NA Rev4
PostPosted: Fri Aug 18, 2017 2:35 pm    Post subject: Reply with quote Reply with quote including images
A good 5W40 will be fine.
Back to top
User is offline
Display posts from previous:
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK2 1990 - 1999 NA & Turbo All times are GMT
Page 1 of 1
Jump to:
