coolant sensor.
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK2 1990 - 1999 NA & Turbo
Author Message
Ja99a
PostPosted: Fri Aug 18, 2017 10:47 am    Post subject: coolant sensor. Reply with quote Reply with quote including images
Help,
I pulled the insides of one of the temperature sensors from the water housing when I removed the plug...
It's a mk2 Turbo rev 1/2, its the lowest sensor on the water housing that has the 22mm socket, I can't seem to find the correct replacement part no can anyone help and provide me a link to a cheap one [Smile]
Back to top
User is offline
abovetherim
1991 Toyota MR2 Mk2 NA Rev1
PostPosted: Fri Aug 18, 2017 4:31 pm    Post subject: Reply with quote Reply with quote including images
Give these guys a call
http://www.tcbparts.co.uk
Back to top
User is offline
markstevieandmads
PostPosted: Fri Aug 18, 2017 5:35 pm    Post subject: Reply with quote Reply with quote including images
Mine went the same way and i believe tcb didnt have any and they are mega bucks from toyota.
Either make do without it by unplugging it or find a secondhand one. I managed to find one secondhand for about a tenner.
One thing i never noticed any difference with and without it.
Back to top
User is offline
Ja99a
PostPosted: Sat Aug 19, 2017 10:04 am    Post subject: Reply with quote Reply with quote including images
Turns out its the cold start temp switch, it's needed to make starting easier.
I just plumed for a 2nd hand one.
Back to top
User is offline
Display posts from previous:
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK2 1990 - 1999 NA & Turbo All times are GMT
Page 1 of 1
Jump to:
