[Mk2] [Turbo] woudl this guide work the same for mk2?
pope_acute
Post by pope_acute »
just wondering if this guide is the same for mk2?
Changing big end and main bearings with the crank in situ
http://www.imoc.co.uk/forums/kb.php?mode=article&k=99
'96 REV4 Turbo, MODS:japspeed exhaust,decat,downpipe,Apexi S-AFC,Apexi T-Timer,greddy intercooler,HKS induction,HKS BOV,sports clutch stage II,Yellow stuff,Matrix 17's,Yoko's & Toyo's
BrianUK
Premium Member
Post by BrianUK »
I'm not sure its identical - but I can tell you its perfectly possible to change the big end and main bearings with the engine in situ - PROVIDED the crank isn't damaged!
:) Brian
pope_acute
Re: [Mk2] [Turbo] woudl this guide work the same for mk2?
thanks :thumleft:
