[Mk2] [Turbo] worth changing Water pump & Oil pump whilst engine out
Author Message
rossonza
Premium Member
PostPosted: Tue Aug 15, 2017 8:30 am    Post subject: [Mk2] [Turbo] worth changing Water pump & Oil pump whilst engine out Reply with quote Reply with quote including images
Is it worth changing the water and oil pump on my engine before it goes back in the car? im doing the timing belt (yet to decide on brand, HKS bit pricey for a belt).
Ross.
Back to top
User is offline
Hez
Premium Member
PostPosted: Tue Aug 15, 2017 12:21 pm    Post subject: Reply with quote Reply with quote including images
If you have the engine out then it's probably worth doing, I would have done the belt with the engine in but now it's out you might aswell. Just use a OEM belt like blueprint or get a Toyota, both will do the job just as well fitted properly.
Back to top
User is offline
rossonza
Premium Member
PostPosted: Tue Aug 15, 2017 1:19 pm    Post subject: Reply with quote Reply with quote including images
sorry should have been clearer. i bought a replacement engine off a member on here.
so ive got the new one (off the imoc forum) in the garden, and the original still in the car.
i plan on building the new engine up on the engine stand. so belts etc can be changed nice and easily.
Sure, ill stick to a decent brand for the belt. just need to find the belt part number and have a look at pricing.
[thumleft]
Back to top
User is offline
Gazza_DJ
Premium Member
1997 Toyota MR2 Mk2 NA Rev4
PostPosted: Tue Aug 15, 2017 1:22 pm    Post subject: Reply with quote Reply with quote including images
Just get a Toyota belt. They are about 40.
Back to top
User is offline
rossonza
Premium Member
PostPosted: Tue Aug 15, 2017 1:58 pm    Post subject: Reply with quote Reply with quote including images
Will do Gazza, didnt realise they were so cheap [thumleft]
Back to top
User is offline
Gazza_DJ
Premium Member
PostPosted: Tue Aug 15, 2017 2:08 pm    Post subject: Reply with quote Reply with quote including images
Yeah, the belts aren't expensive. If you're doing the full service don't forget the tensioner pulleys and hydraulic tensioner itself. If history is a bit unknown then it's worth just replacing everything so you know it's good [thumleft]
Back to top
User is offline
rossonza
Premium Member
PostPosted: Tue Aug 15, 2017 2:34 pm    Post subject: Reply with quote Reply with quote including images
sure sounds good to me. thanks for your input [thumleft]
Back to top
User is offline
markstevieandmads
PostPosted: Tue Aug 15, 2017 2:54 pm    Post subject: Reply with quote Reply with quote including images
Im doing the same but with my original engine out the car.
Ive got to get an exhaust stud repaired which means head off...which means new hg and bolts and so i thought might as well do cambelt too so might as well take engine out.
Also gonna get a seal and gasket kit and renew them all while its out and new clutch if i can find one for a decent price.
Problem is you need to set a limit on where you gonna stop refurbing. I was thinking water and oil pump too but do they really need doing? Mines on 130k (mix of miles and km) and not showing any signs of failure anywhere so it is literally routine for me.
Back to top
User is offline
rossonza
Premium Member
PostPosted: Tue Aug 15, 2017 3:06 pm    Post subject: Reply with quote Reply with quote including images
true mate....could end up spending more than ive spent on the engine itself.........
Back to top
User is offline
Gazza_DJ
Premium Member
PostPosted: Tue Aug 15, 2017 3:07 pm    Post subject: Reply with quote Reply with quote including images
Considering oil pump is a sump off job if you're going to do it then this is the time to do it. Not about removing a sump with some oil still in it (as it never drains fully) from underneath when you can do it in relative comfort on an engine stand [thumleft]
Back to top
User is offline
rossonza
Premium Member
PostPosted: Wed Aug 16, 2017 7:35 am    Post subject: Reply with quote Reply with quote including images
this is true [Smile]
Back to top
User is offline
Display posts from previous:
Page 1 of 1
Jump to:
