[Mk2] [Turbo] Help me remove this aftermarket wheel/boss AAARRGGHH!!
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK2 1990 - 1999 NA & Turbo -> Modifications
Author Message
ste_brough
Premium Member
PostPosted: Sat Aug 05, 2017 8:14 pm    Post subject: [Mk2] [Turbo] Help me remove this aftermarket wheel/boss AAARRGGHH!! Reply with quote Reply with quote including images
Someone please help me, I cannot for the life of me get this crappy aftermarket wheel boss off! I've wiggled and jiggled, kicked, punched, hit with a hammer, plus liberal with WD40 but it wont budge.
[/img]
_________________
** Disclaimer **
All comments made are my opinion only. Please do not get offended.
Back to top
User is offline
pbmr2
Premium Member
PostPosted: Sat Aug 05, 2017 8:33 pm    Post subject: Reply with quote Reply with quote including images
there is the no tools way of doing it. put the nut back on a couple of turns, put the aftermarket wheel back on firmly. put the driver's seat back and go ape-poop trying to pull it off.
The nut stops it hitting you in the face.
The other way is to use a bearing/hub puller.
Back to top
User is offline
RST
Premium Member
2002 Toyota MR2
PostPosted: Fri Aug 11, 2017 1:16 am    Post subject: Reply with quote Reply with quote including images
Having sustained a hefty neck / arm injury following the "forum" type procedure for steering wheel removal before, all I can say is use the correct tool for the job and its a 1min operation with no effort...
USE A BEARING PULLER!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
..dont risk harm to yourself -it's not worth it.
Back to top
User is offline
Gazza_DJ
Premium Member
1997 Toyota MR2 Mk2 NA Rev4
PostPosted: Fri Aug 11, 2017 9:25 am    Post subject: Reply with quote Reply with quote including images
Put the nut that secures the boss in place back on by 4 or 5 threads. Attach the wheel again. This will give you more leverage to work it off.
Usually those type of aftermarket ones pretty much fall off though.
Or get a puller.
Back to top
User is offline
Jayridium
PostPosted: Thu Sep 07, 2017 8:41 am    Post subject: Reply with quote Reply with quote including images
I think looking at it that the splines arent a match, so at 6'0clock in the picture the splines are engaged properly, by 3/9 oclock they peaks of the steering column are digging into the peaks (rather than the troughs) of the boss.
So please be ware that the splines on your steering column may be be damaged.
Back to top
User is offline
Display posts from previous:
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK2 1990 - 1999 NA & Turbo -> Modifications All times are GMT
Page 1 of 1
Jump to:
