Steam coming from thermostat area
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK2 1990 - 1999 NA & Turbo
Author Message
Sbsoulby
Premium Member
PostPosted: Fri Aug 04, 2017 9:19 am    Post subject: Steam coming from thermostat area Reply with quote Reply with quote including images
Hi guys,
Coming back with another issue,
After a decent drive/ some fast driving I get steam coming from near the intercooler, the drivers(UK) side near right of the heat sheild, I'm assuming it's the thermostat area
The temperature gauge stays normal sitting half way
I'm thinking it could be the thermostat o ring? Or air in the system
I've ordered a new thermostat and Toyota red coolent so I'll do a coolent change
Was wondering if any one else has had the same thing happen and what resolved it
Back to top
User is offline
MartinF
Premium Member
PostPosted: Fri Aug 04, 2017 9:20 am    Post subject: Reply with quote Reply with quote including images
Is your car a turbo, if so what revision ?
_________________
Blue Lexus RCF
Black MKIV UK Manual Supra
Green MK2 MR2 Tin Top
Back to top
User is offline
Sbsoulby
Premium Member
PostPosted: Fri Aug 04, 2017 10:47 am    Post subject: Reply with quote Reply with quote including images
Sorry, yes should of said
It's rev 3 turbo gts
Back to top
User is offline
MartinF
Premium Member
PostPosted: Fri Aug 04, 2017 11:42 am    Post subject: Reply with quote Reply with quote including images
OK, was going to suggest the hose from hell if you were an earlier rev turbo, but it is different on a Rev3.
Back to top
User is offline
pbmr2
Premium Member
PostPosted: Fri Aug 04, 2017 1:30 pm    Post subject: Reply with quote Reply with quote including images
worth checking the 2 small hoses from the oil cooler, just to the right of the thermostat on the block, under the manifold. hoses from hell on earth.
they connect from the oil cooler to the 2 bypass water pipes just under the manifold.
Back to top
User is offline
Sbsoulby
Premium Member
PostPosted: Fri Aug 04, 2017 3:06 pm    Post subject: Reply with quote Reply with quote including images
Hoses from hell, not sure I like the sound of them, I guess they are a pita to change
Back to top
User is offline
Draven
PostPosted: Tue Aug 15, 2017 9:32 am    Post subject: Reply with quote Reply with quote including images
Yes, they are under the manifold possibly the most difficult place to reach. hence the name.
Back to top
User is offline
Display posts from previous:
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK2 1990 - 1999 NA & Turbo All times are GMT
Page 1 of 1
Jump to:
