[Mk2] [Turbo] Electronic Speed Sensor - compatibility between NA and Turbo?
Author Message
Gazza_DJ
Premium Member
1997 Toyota MR2 Mk2 NA Rev4
PostPosted: Mon Jul 31, 2017 8:10 pm    Post subject: [Mk2] [Turbo] Electronic Speed Sensor - compatibility between NA and Turbo? Reply with quote Reply with quote including images
One of the pins is broken on my turbo gearbox speed sensor. As I'm converting an NA car, can I use the NA's speed sensor? The PN's are different but that doesn't always mean they aren't compatible.
Back to top
User is offline
alanmr2turbo
PostPosted: Tue Aug 01, 2017 7:58 am    Post subject: Reply with quote Reply with quote including images
simple answer is No they are completely different
Back to top
User is offline
Gazza_DJ
Premium Member
PostPosted: Tue Aug 01, 2017 8:27 am    Post subject: Reply with quote Reply with quote including images
Another part for the ever growing parts list then! [d'oh!]
Back to top
User is offline
pbmr2
Premium Member
PostPosted: Tue Aug 01, 2017 8:57 am    Post subject: Reply with quote Reply with quote including images
yeah just went though this, they are hard to find sensors. new ones are available but costly, used ones seem light on the ground in the UK, had to get one from the US. cost about 95 with delivery.
Back to top
User is offline
Gazza_DJ
Premium Member
PostPosted: Tue Aug 01, 2017 10:36 am    Post subject: Reply with quote Reply with quote including images
Will see what's out there. Looking the the parts catalogue the same part is used on some RAV4's, Celica's, Corolla's, and Camry's which widens the search pool a bit.
Found what looks to be a compatible 3rd party part for ~40 which I may try while searching for a good used OEM one.
Back to top
User is offline
jon
Premium Member
PostPosted: Tue Aug 01, 2017 4:34 pm    Post subject: Reply with quote Reply with quote including images
The connector looks the same between the NA and Turbo versions, it's held on with 3 screws so you may be able to disassemble them both and make a working Turbo one?
Back to top
User is offline
Gazza_DJ
Premium Member
PostPosted: Tue Aug 01, 2017 4:51 pm    Post subject: Reply with quote Reply with quote including images
I was thinking that... Seeing as the one I have has a broken pin anyway I'll dismantle it and see what's inside I guess!
Back to top
User is offline
Display posts from previous:
Page 1 of 1
Jump to:
