Turbo Blocks
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK2 1990 - 1999 NA & Turbo
Author Message
blogsy
PostPosted: Mon Jul 31, 2017 5:45 pm    Post subject: Turbo Blocks Reply with quote Reply with quote including images
Got the chance to buy a rev5 turbo block and head with the strengthened water pump area. I'm just not sure that I'll be able to tell if it's a rev3 or rev5 by looking at that. any other ways to tell the difference, or has anyone got a picture of the rev3 pump area and the rev5 stronger pump area. Really would appreciate any help.
Back to top
User is offline
androo007
Premium Member
PostPosted: Tue Aug 01, 2017 6:27 pm    Post subject: Reply with quote Reply with quote including images
Check out my build thread. I have a REV 5 NA block with the stronger waterpump area.
Back to top
User is offline
blogsy
PostPosted: Tue Aug 01, 2017 7:02 pm    Post subject: Reply with quote Reply with quote including images
Excellent, thanks Andrew just what I need. Why is the rev 5 N/A block going to be better than a rev 5 turbo block? [thumleft]
Back to top
User is offline
Dale_V
PostPosted: Wed Aug 02, 2017 6:09 am    Post subject: Reply with quote Reply with quote including images
They're not better (or inferior), they're just easier to source than a rev5 turbo block.
Back to top
User is offline
Ja99a
PostPosted: Sat Aug 19, 2017 10:11 am    Post subject: Reply with quote Reply with quote including images
What happens to the water pump area of the block?
why does it matter?
im curious?
Back to top
User is offline
rev2rich
Premium Member
1991 Toyota MR2 Mk2 Turbo Rev2
PostPosted: Sat Aug 19, 2017 11:33 am    Post subject: Reply with quote Reply with quote including images
Weakest point of the block and prone to crack [thumleft]
Back to top
User is offline
blogsy
PostPosted: Sat Aug 19, 2017 1:13 pm    Post subject: Reply with quote Reply with quote including images
Turned out not to be the stronger block. Would not have known if not for that advice about the squared off edge by the water pump, so thanks again. I'v been told that a week point is between cylinders 2 and 3.
Back to top
User is offline
Gazza_DJ
Premium Member
1997 Toyota MR2 Mk2 NA Rev4
PostPosted: Mon Aug 21, 2017 1:01 pm    Post subject: Reply with quote Reply with quote including images
A late 5S block addresses both of those issues.
Back to top
User is online now
androo007
Premium Member
PostPosted: Mon Aug 21, 2017 9:10 pm    Post subject: Reply with quote Reply with quote including images
2/3 weak spot tends to be the rev 3s as they had the poorest casting.
Once you hit 450-500+ it's a game of luck on the 3s.
It might last 2 minutes, or 30,000 no problem at 600hp.
Back to top
User is offline
blogsy
PostPosted: Tue Aug 22, 2017 6:25 am    Post subject: Reply with quote Reply with quote including images
To many little things that you need to research and change with the 5s block, like what water pump. Do you drill out the block to suit the 3s head or just use the head gasket that ATS make, Do you really need oil squirters etc etc. Would be great if someone could do a definitive wright up on how to put one together. But like androo says 3s is probably good enough for most peoples power needs.
Back to top
User is offline
Gazza_DJ
Premium Member
PostPosted: Tue Aug 22, 2017 12:37 pm    Post subject: Reply with quote Reply with quote including images
http://www.mr2oc.com/61-3sgte-turbo/395274-how-build-5sgte.html
Back to top
User is online now
blogsy
PostPosted: Thu Aug 24, 2017 5:36 pm    Post subject: Reply with quote Reply with quote including images
Want to build one now [Think]
Back to top
User is offline
Display posts from previous:
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK2 1990 - 1999 NA & Turbo All times are GMT
Page 1 of 1
Jump to:
