[Mk2] [Generic] Spinning Gear Lever Knob
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK2 1990 - 1999 NA & Turbo -> Modifications
Author Message
MR22
PostPosted: Wed Jul 26, 2017 10:03 am    Post subject: [Mk2] [Generic] Spinning Gear Lever Knob Reply with quote Reply with quote including images
Have you suffered from the dreaded spinning gear lever knob problem?
I've tried several different methods to stop this but without success. The threaded nylon insert within the knob eventually wears away and the knob spins. As it's the Rev 5 knob I'd like to keep it.
Does anyone know a way to cure this, without permanently gluing it on, so enabling the knob to be undone and allowing the gear lever plastic surround to still be taken off?
Back to top
User is offline
pbmr2
Premium Member
PostPosted: Wed Jul 26, 2017 2:08 pm    Post subject: Reply with quote Reply with quote including images
I opted for a new knob, ordered a TRD one and it cured the issue.
Might get the stock one refurbished at some point.
Back to top
User is offline
robbie_742003
1996 Toyota MR2 Mk2 Turbo Rev3
PostPosted: Mon Jul 31, 2017 6:44 pm    Post subject: Re: [Mk2] [Generic] Spinning Gear Lever Knob Reply with quote Reply with quote including images
If you could find some kind of filler like no more nails or summat that sets rock hard, you could fill it, then drill and re tap it?
Back to top
User is offline
Ja99a
PostPosted: Sun Oct 01, 2017 11:35 am    Post subject: Reply with quote Reply with quote including images
Some rubber hose will fix that, push it into the hole then wind the gear knob into the hose, has to be tight.
Back to top
User is offline
Display posts from previous:
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK2 1990 - 1999 NA & Turbo -> Modifications All times are GMT
Page 1 of 1
Jump to:
