[Mk2] [Generic] Hub side toe rod bush
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK2 1990 - 1999 NA & Turbo -> Modifications
Author Message
pbmr2
Premium Member
PostPosted: Tue Jul 25, 2017 7:14 pm    Post subject: [Mk2] [Generic] Hub side toe rod bush Reply with quote Reply with quote including images
Hey,
So the bushing on the top of the hub was basically end of life and way to floppy. Had them pressed out thinking it would be a simple case of grabbing some poly bushes to replace them with (rest of the suspension is now poly bushed) but had no luck finding the correct bushes.
Do any of you know where to get poly bushes for this?
So far the only option seems to be a 14mm version of the stock bush. Which would work fine of course but would like to have everything poly if possible.
Back to top
User is offline
Display posts from previous:
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK2 1990 - 1999 NA & Turbo -> Modifications All times are GMT
Page 1 of 1
Jump to:
