Fuel issue
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK2 1990 - 1999 NA & Turbo
Author Message
Ja99a
PostPosted: Sat Jul 22, 2017 12:52 pm    Post subject: Fuel issue Reply with quote Reply with quote including images
Guys my turbo has just come back onto the road after 8 years standing....
it runs great in low rpm range, but the wideband tells me I have fueling issue when the car makes boost the motor leans out, it bangs and hesitates etc, I'm looking for some places to check:
Im planning on checking / doing the following:
Replace fuel filter - just in case.
it's got a walbro, could this have gone bad?
How about the fuel pressure regulator, could it be faulty, it's running a stock unit...
Thoughts please.
Back to top
User is offline
MartinF
Premium Member
PostPosted: Sat Jul 22, 2017 3:33 pm    Post subject: Reply with quote Reply with quote including images
If it's been sitting that long i think i would be checking for rust in the fuel tank clogging the pump pick up and maybe causing problems with your Walbro pump as well.
_________________
Blue Lexus RCF
Black MKIV UK Manual Supra
Green MK2 MR2 Tin Top
Back to top
User is offline
benjo
Premium Member
PostPosted: Sat Jul 22, 2017 7:02 pm    Post subject: Reply with quote Reply with quote including images
Old fuel as well it's does go bad
_________________
Too weird to live, to rare to die
Back to top
User is offline
pbmr2
Premium Member
PostPosted: Sat Jul 22, 2017 8:09 pm    Post subject: Reply with quote Reply with quote including images
what does the inside of the dizzy cap look like? could be fouled up.
the old fuel (assume you changed all the fuel and oils?) won't be rich enough anymore. needs replacing.
Back to top
User is offline
Ja99a
PostPosted: Wed Jul 26, 2017 11:10 pm    Post subject: Reply with quote Reply with quote including images
The fuel was bad it smelled like white spirit, it was almost empty so I just put 30 quid in to mix it down.
Still doesn't smell great, I will change the fuel filter and pray I don't need a drop the tank as I hate doing that job...
Dizzy looked ok minor furred up wet n dryer the contacts have ordered a replacement rotor arm.
Will update when bloody battery is charged lol
Back to top
User is offline
Ja99a
PostPosted: Sat Aug 19, 2017 10:13 am    Post subject: Reply with quote Reply with quote including images
Sorted, left too long with tank empty rusted tank blocked pickup. sorted now...
Back to top
User is offline
Display posts from previous:
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK2 1990 - 1999 NA & Turbo All times are GMT
Page 1 of 1
Jump to:
