[Mk2] [NA] Hub to strut nut torque spec
Author Message
Winger300
PostPosted: Tue Jul 04, 2017 9:56 pm    Post subject: [Mk2] [NA] Hub to strut nut torque spec Reply with quote Reply with quote including images
I'm about to install some Camber bolts, and was wondering about how I should torque up the original lower bolt after fitting.
I understand the torque spec of the original bolts is something like 180 ft lbs. I've also seen 255Nm mentioned.
What is the correct torque spec?
How many people have a torque wrench big enough for this job? Can I get away without one, just using a breaker bar and guesswork?
Back to top
User is offline
Gazza_DJ
Premium Member
1997 Toyota MR2 Mk2 NA Rev4
PostPosted: Wed Jul 05, 2017 8:57 am    Post subject: Reply with quote Reply with quote including images
1993 repair manual states 173NM
Rear - https://drive.google.com/file/d/0B-dpUpxzr96YcXRMNWdKVjByTHM/view?usp=sharing
Front - https://drive.google.com/file/d/0B-dpUpxzr96Ya0JQbHNjSTBTdkE/view?usp=sharing
Most 1/2inch drive torque wrenches should be able to manage that.
Back to top
User is offline
abovetherim
1991 Toyota MR2 Mk2 NA Rev1
PostPosted: Wed Jul 05, 2017 9:09 am    Post subject: Reply with quote Reply with quote including images
Just checked 91 bgb and this states 188 ft-lb, 255 Nm
Realistically an 18" breaker bar done up pretty tight will suffice. I have changed out my shocks a couple of times and reused these bolts and just done them up tight! No probs
Back to top
User is offline
Gazza_DJ
Premium Member
PostPosted: Wed Jul 05, 2017 9:20 am    Post subject: Reply with quote Reply with quote including images
I think the 1991 edition is a typo personally. Certainly wouldn't be the only example of an earlier edition BGB getting a torque value wrong / conversion factor wrong.
Back to top
User is offline
Winger300
PostPosted: Wed Jul 05, 2017 5:39 pm    Post subject: Reply with quote Reply with quote including images
Ok thanks.
So basically, if I apply around 56Kg to the end of an 18" breaker bar, that should do it.
Back to top
User is offline
pbmr2
Premium Member
PostPosted: Thu Jul 06, 2017 3:06 pm    Post subject: Reply with quote Reply with quote including images
FT mate, should do the trick
Back to top
User is offline
Gazza_DJ
Premium Member
PostPosted: Thu Jul 06, 2017 3:10 pm    Post subject: Reply with quote Reply with quote including images
How much is that in dugga dugga's?
Back to top
User is offline
pbmr2
Premium Member
PostPosted: Tue Jul 11, 2017 12:49 pm    Post subject: Reply with quote Reply with quote including images
dunno not got a compressor anymore. all manual [Very Happy]
it's "that" much with the big bar and a spanner locking the other side. [Laughing]
Back to top
User is offline
Gazza_DJ
Premium Member
PostPosted: Tue Jul 11, 2017 12:51 pm    Post subject: Reply with quote Reply with quote including images
About "hhhhhnnnngh ya xxxxxx" tight?
Back to top
User is offline
Display posts from previous:
Page 1 of 1
Jump to:
