[Mk2] [Turbo] Hose from hell & hose from hell on earth
rossonza
Premium Member
Post by rossonza »
Does anyone have any definitive UK part numbers and any o ring/gasket info?
ive read a few guides and im getting different part numbers from them, id rather get the correct UK part numbers for the hoses and orings/gaskets that need replacing.
If anyone can help, would be great.
Ross.
SonicSW20
Re: [Mk2] [Turbo] Hose from hell & hose from hell on earth
Post by SonicSW20 »
Assuming your garage is correct "1993 Toyota MR2 Mk2 Turbo Rev2"...
http://www.japan-parts.eu/toyota/jp/199 ... ngine-fuel
All part numbers can be found here.
rev2rich
Post by rev2rich »
Have 2 unused in the garage... if it is the hose that sits under the turbo...
http://www.turbomr2.com/MR2/HowTo/Engin ... GTE-02.htm
rossonza
Premium Member
Post by rossonza »
rev2rich wrote:Have 2 unused in the garage... if it is the hose that sits under the turbo...
Image Replaced With URL For Quote http://www.turbomr2.com/MR2/HowTo/Engin ... nished.jpg
PM'd
rossonza
Premium Member
Post by rossonza »
rich sorted me for the coolant hose number 2/6?
Whats the remaining hose i need...and does anyone have one?
rev2rich
Post by rev2rich »
Last 2 are the main pipes that carry the water to and from the radiator next to the fuel tank... they have tabs that over time can cause the pipes to crack and leak :thumleft:
rossonza
Premium Member
Post by rossonza »
rev2rich wrote:Last 2 are the main pipes that carry the water to and from the radiator next to the fuel tank... they have tabs that over time can cause the pipes to crack and leak :thumleft:
worth getting?
pbmr2
Post by pbmr2 »
Think you have mixed up the heater pipes with the radiator pipes there :wink:
The heater pipes that go over the fuel tank, the right hand one can rip and leak. The radiator pipes are strong and last very well.
rev2rich
Post by rev2rich »
yep my bad ](*,) ](*,)
and yes worth doing as you never have to do again.. just replace with hose :thumleft: :thumleft:
rossonza
Premium Member
Post by rossonza »
rev2rich wrote:yep my bad ](*,) ](*,)
which hose is it on the picture?
