[Mk2] [Generic] rear foglight wiring
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK2 1990 - 1999 NA & Turbo -> Electrical
Author Message
thomp1983
PostPosted: Thu Jun 22, 2017 11:59 am    Post subject: [Mk2] [Generic] rear foglight wiring Reply with quote Reply with quote including images
my latest mr2 is an import and as such doesn't have a rear fog light. it has rev 3 lights so im going to quad mod them to integrate the fog light, i have obtained a uk rear switch to activate them and im happy wiring them up using a 4 pole relay.
my question is my speedo unit has the tell tale symbol in it for the rear fog light so i want to use it as i need one for the mot i'm just not sure how to wire it up, i know i could just earth one side of the bulb in the dash cluster and then run the feed out to the fog light from the switch via the other side of the dash bulb so that will illuminate when the switch is on but it doesn't seem right to me to run the full current through a small dash bulb or is this how it normally works on a uk spec car?
thanks
chris
Back to top
User is offline
Display posts from previous:
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK2 1990 - 1999 NA & Turbo -> Electrical All times are GMT
Page 1 of 1
Jump to:
