Is there one? ive trawled ebay and found them for other cars. Just wondered if anyone had re-located the filter to allow easier changes.
Ross.
[Mk2] [Turbo] Oil filter relocation kit
Re: [Mk2] [Turbo] Oil filter relocation kit
They are avalible but its a tight fit on the 3sgte. Some will fit and others wont. There is a few threads on here about people having success its probably worth trying the search box if you can figure out how it works
I have a greddy one fitted but i dont know if prevous owner modified it to fit
use google advance search for oil filter relocation but put imoc as the only website to search its much better.
What revision engine do you have?
ashley wrote:What revision engine do you have?
rev 2 turbo ashley.
I've just removed this from my 5S engine, which would be a bolt on for you:
- Mocal sandwich plate with side feed entrance/ exit take off plate (bolts onto block)
- 2 x AN10 fittings for take off plate
- 2 x AN10 stainless braided lines with straight hose ends one end, and 90 dgree fittings other end
- Mocal remote oil filter plate
- 2 x AN10 fittings for remote oil plate
- AN10 one way valve to prevent oil drain back from filter when engine off
You'd have to start using slightly larger diameter filters- the Camry v6 ones are a direct fit.
I've got some pictures of it installed, and can take some of all the fittings for you if you are interested...or I could give you all the part references if you want to replicate it yourself brand new Not sure what I'd ask for the kit, I'd need to look at what I paid...but it's an option for you.
ashley wrote:I've just removed this from my 5S engine, which would be a bolt on for you:
amazing, thank you. Sure part numbers wouldnt go a miss
If i keep my rev 2 i might be after the same thing if you can post up part numbers.
Cool beans, I'll put together a list tomorrow
OK...shopping list:
Take off plate and top hat
http://www.jjcraceandrally.com/race/san ... d-1-2bsp-2
Compact remote oil filter plate
http://www.jjcraceandrally.com/race/san ... ilter-head
4 fittings
http://www.jjcraceandrally.com/race/san ... -adaprtors
4 dowty washers
http://www.jjcraceandrally.com/race/san ... lter-heads
2 x 90 degree hose ends -10
http://www.speedflowshop.co.uk/-10-an-9 ... 1758-p.asp
2 x Straight hose ends -10
http://www.speedflowshop.co.uk/-10-an-s ... 1740-p.asp
2m Braided hose -10 (might get away with 1 depending on where mounting)
http://www.speedflowshop.co.uk/stainles ... 2433-p.asp
One way valve
https://www.merlinmotorsport.co.uk/p/go ... s-g-fcv-10
-10 female to female connector
http://www.speedflowshop.co.uk/-10-an-s ... 2165-p.asp
If my maths is correct- £422.33 excluding postage, including VAT...but you may find stuff cheaper by hunting around.
I'd be up for selling mine (hoses already made up) for significantly less than that...drop me a pm if interested
4 fittings
4 dowty washers
One way valve
