I'm going to be refreshing my engine. I don't suppose there is some list of the spring band clip sizes used on the car and the bolts the car uses on the engine.
Save me going out there and playing the guessing game as god knows where my verniers are!
[Mk2] [Turbo] Clips & Bolts sizes used on the 3s-GTE engine
My Blog on Miami GT4 kit car build using MR2 Donor Car
http://miamigt4kitcar.blogspot.co.uk/
twitter for photo's as I'm building -
www.twitter.com/iwanabeaferret
Re: [Mk2] [Turbo] Clips & Bolts sizes used on the 3s-GTE engine
The bolt sizes are given in the bgb. Unfortunately i can't say the same for the clamps
isnt that the whole car though? not whatts just used on the engine?
Yeah, there is no single list containing all bolts, sizes, thread pitches etc. pertaining solely to the short block/long block/partial assembly
mr2magic wrote:Yeah, there is no single list containing all bolts, sizes, thread pitches etc. pertaining solely to the short block/long block/partial assembly
yea bit useless unfortunately then, nevermind
Maybe not quite what you wanted to hear but useless? Just means your going to have to do the work yourself instead of relying on others.
mr2magic wrote:Maybe not quite what you wanted to hear but useless? Just means your going to have to do the work yourself instead of relying on others.
I meant the book not your reply. But I'm afraid it is useless id have to buy every bolt listed, as what is on the engine isnt known and then have loads of wasted money and left over bolts.
I wasn't relying on others I was seeing if a forum designed to assist us all, has a knowledge base of this following a search i had performed
My answer wasn't intendend to sound dickish I had the same problem years ago and neglected to note down everything unfortunately.
