[All] [Turbo] standalone ecu boost spikes
Goto page Previous  1, 2
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK2 1990 - 1999 NA & Turbo -> Modifications
Author Message
Al-sw20
1991 Toyota MR2 Mk2 Turbo Rev1
PostPosted: Thu Jun 08, 2017 3:21 am    Post subject: Reply with quote Reply with quote including images
Upgraded CT26 by any chance?
Back to top
User is offline
adamshaw
1998 Toyota MR2 Mk2 Turbo Rev5
PostPosted: Fri Jun 09, 2017 6:41 pm    Post subject: Reply with quote Reply with quote including images
thats the one .... how did you guess? settings seem ok ?
Back to top
User is offline
jimGTS
Premium Member
1997 Toyota MR2 Mk2 Turbo Rev4
PostPosted: Fri Jun 09, 2017 7:05 pm    Post subject: Reply with quote Reply with quote including images
adamshaw wrote:
oh i tried turning set gain to 1.00 from 0.13 and had no power revs went turbo didnt hardly spool. back down to 0.13kpa and woosh turbo kicks in strong
not sure what that tells us? [thumleft]
Sounds odd to me. The idea of set gain is it's at this point boost controller takes over from the spring in the wastegate.
If anything it should spool quick and give you a potential spike, ha.
You need a nice straight empty road and take a good look at your gauge when out your foot flat to the floor.
The peak feature should also tell you the max boost you hit after the pull.
Ie it shot to 1.4 but then levelled off a 1.2.
Back to top
User is offline
adamshaw
PostPosted: Mon Jun 12, 2017 7:51 am    Post subject: Reply with quote Reply with quote including images
Thanks guys
on idle its ticking over around -80. i know it should be negative buy should it read -99. i read somewhere it does otherwise a vacuum leak? but i tought anything around -75 was fine?
Back to top
User is offline
Al-sw20
PostPosted: Sun Jun 18, 2017 6:09 am    Post subject: Reply with quote Reply with quote including images
Upgraded CT26s are reknown for unstable boost.
Back to top
User is offline
Display posts from previous:
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK2 1990 - 1999 NA & Turbo -> Modifications All times are GMT
Page 2 of 2
Jump to:
