[Mk2] [Turbo] fuel hose size
Bear87
Post by Bear87 »
Hi guys can anyone please confirm the oem size of the fuel hose from fuel filter to fuel rail? after a google i saw 7mm mentioned?
also is the return pipe the same size?
ta very much
rev2rich
Re: [Mk2] [Turbo] fuel hose size
Post by rev2rich »
Think I have that siting in my garage if you need :thumleft: or if you are going to run new braided lines -10 in -6out so if in the future you won't have a retriction if you upgrade again :evil:
Bear87
Post by Bear87 »
Thanks Rich but my issue is i need to re route the original pipe so i need it a bit longer #-o
Its only temporary untill the car gets tuned then will prob get some nice braided lines in. :thumleft:
Thanks tho mate
Bear87
Post by Bear87 »
rev2rich wrote:Think I have that siting in my garage if you need :thumleft: or if you are going to run new braided lines -10 in -6out so if in the future you won't have a retriction if you upgrade again :evil:
Cheers Rich. Yea once i know the engine is okay i dont mind doing it once instead of 3 times (learn from your mistakes) lol
But for now trying to stay as stock as possible so the garage dont assume that mods are the issue.
