[Mk2] [Generic] Any Toad ai606 experts / installers here? Issue with no indicators
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK2 1990 - 1999 NA & Turbo -> Electrical
Author Message
monkeyra
Premium Member
1990 Toyota MR2 Mk2 V6
PostPosted: Thu May 18, 2017 7:52 pm    Post subject: [Mk2] [Generic] Any Toad ai606 experts / installers here? Issue with no indicators Reply with quote Reply with quote including images
Hi
I've tried to install a toad ai606 I've had kicking around for a number of years. Wired it up as per the instructions, it locks and unlocks on the keyfob, bit no chirp, no indicators flashing and more importantly the red led doesn't illuminate at all.
I've checked the 15a Fuse for the indicators, that's fine.
Any pointers / advise?
Sadly I don't have the four digit pin code, so unable to access any menus.
_________________
SW20 Rev1 Supercharged 2GR-FE Powered Trackday Car.
Back to top
User is offline
thomp1983
PostPosted: Thu May 18, 2017 10:04 pm    Post subject: Reply with quote Reply with quote including images
Not sure on the led but both the other issues are options that can be turned off.
The last ai606 I had didn't have a 4 digit code there was a sequence you did with the key and fob to get into the programming menu
Back to top
User is online now
monkeyra
Premium Member
PostPosted: Fri May 19, 2017 6:36 am    Post subject: Reply with quote Reply with quote including images
I've not come across that before, all the instructions I can find online say I need to input my 4-pin code first.
Back to top
User is offline
thomp1983
PostPosted: Fri May 19, 2017 11:39 am    Post subject: Reply with quote Reply with quote including images
I may be wrong it's been 18 months since I've played with one but I don't remember having a security pin.
The other option is to sit and go through every code combination I've had to do it before and it's tedious but once you get into a rhythm it doesn't take that long
Back to top
User is online now
PostPosted: Fri May 19, 2017 3:48 pm    Post subject: Re: [Mk2] [Generic] Any Toad ai606 experts / installers here? Issue with no indicators Reply with quote Reply with quote including images
monkeyra wrote:
Hi
I have had two units over the years, on one occasion i swapped the whole thing from my rev 1 to rev 3.
All these functions plus more are turned on and off after you enter the four digit pin that came with the alarm.
I didn't have this pin for either set up but on both occasions MR-toadinstaller (that may not be his correct user name) sent me the codes via pm after i send the units serial number to him.
I still have a main control unit and two or three fobs in the shed if you need a spare [thumleft]
Back to top
User is offline
monkeyra
Premium Member
PostPosted: Sat May 20, 2017 5:33 am    Post subject: Reply with quote Reply with quote including images
Solved it last night. I *thought* I had the ignition feed wired into an ignition 12v wire, but it turned out to be permanent 12v when I checked it with my multimeter. Rewired that and it all works perfectly now!
Back to top
User is offline
Display posts from previous:
Post new topic   Reply to topic       www.imoc.co.uk Forum Index -> MR2 MK2 1990 - 1999 NA & Turbo -> Electrical All times are GMT
Page 1 of 1
Jump to:
