Hi Guys/Gals
Looking for some advise,
Im looking to make my mr2 into a really good handling back road car (not track)
My plan is to keep my standard rev5 wheels because there nice and light and i prefer the handling on them compared to the 17" i have also
I also have plans to add front and rear whiteline arbs
What my question is is it a worth while upgrade on the n/a to the Black Bilstiens that are on the turbo and Tein springs...... or do i hold out for a set of yellows (if they ever come up)
Are the black bilstiens a worth while upgrade for the n/a
Thanks in advance
Steven
Rev5 N/A Suspension Upgrade
Re: Rev5 N/A Suspension Upgrade
L14HRE wrote:Hi Guys/Gals
Thanks in advance
Steven
Hi,
I bought a new set of yellow for me rev5 Turbo, I find them great on the road and the odd track day, but i don't have an experience with coil overs to compare them with.
My car came with black blisteins, which were nice but a bit jaded, the yellows seem a bit harder, well worth the investment if you are planning on keeping the car.
T
Thanks man,
only problem is yellow billys seem to be like hens teeth!! and for what i paid for the car im reluctant to spend that on new ones......
When we bought our v6, it had the rebuildable earlier REv2 (I think) struts with adjustable Koni dampers with stock springs, it was way better than stock struts I had on my Rev 5. I plan on buying either 30-40mm spax springs instead of the oem springs.
Currently I have tein flex coil overs fitted but when they're shot, I'm putting back my Koni shocks in, best ride handling imo
i just bought Yellow Bilsteins for my rev3 turbo and yeah they weren't cheap consider that's just the dampers! You have rebuildable struts (uk n/a I presume?) so just go for upgraded dampers and springs and you'll be fine. You can get Yellow Bilsteins from Germany for about 100quid less than the UK if you can wait approx 2wks for delivery
raptor95GTS wrote:i just bought Yellow Bilsteins for my rev3 turbo and yeah they weren't cheap consider that's just the dampers! You have rebuildable struts (uk n/a I presume?) so just go for upgraded dampers and springs and you'll be fine. You can get Yellow Bilsteins from Germany for about 100quid less than the UK if you can wait approx 2wks for delivery
Its a rev5 n/a i have so not sure if i can rebuild them?
I'm 99% sure the rev 5 NA standard shocks are rebuildable. If you're not doing trackdays then I wouldn't be so quick to overlook OEM dampers if they're replaced or in good condition. I personally have Spax PSX adjustable dampers and springs on my Rev 5 which are a good compromise between track and road, but I wouldn't recommend them for JUST road use. I've tried a few different suspension setups over the years but I still think my bone stock rev2 N/A was one of the best for blasting down a B-road as it was compliant and predictable. Don't get me wrong on track or big open sweeping roads it would be a bit too soft but B-roads it felt right. I'm sure new or low mileage black or yellow bilsteins would also be a great option though.
IIRC I read somewhere about the race guys changing the shock oil in their dampers too, which is a cheap way of uprating your existing dampers if you can do it.
Have a look at this pic below, should help you see if your struts are rebuildable
1998 MR2 Rev5 NA (Road & Track)
1998 Porsche Boxster 986 (Weekend)
2007 Ford S-Max Titanium (Family Hack!)
Thanks guys,
There is nothing wrong with the shocks or springs i have.....
just got the opportunity of a set of HSD Monopros............
Also considering just leaving the suspension and getting front and rear whiteline arbs instead
these look based upon stick strut but new and built up to your own spec, but will be expensive...
http://wilhelmraceworks.com/koni-coilovers
juliankv73 wrote: these look based upon stick strut but new and built up to your own spec, but will be expensive...
yeah I looked at them, holy smokes never were cheap and after the dollar rate crash
