[Mk2] [Turbo] Replacing Distributor oring
killerferret666
Post by killerferret666 »
Is it a simple case of being able to just whip off the distributor (marking the position etc... obviously) or do I need to take anything else off, like Cam cover etc...
My Blog on Miami GT4 kit car build using MR2 Donor Car
http://miamigt4kitcar.blogspot.co.uk/
twitter for photo's as I'm building -
www.twitter.com/iwanabeaferret
jimGTS
Re: [Mk2] [Turbo] Replacing Distributor oring
Post by jimGTS »
undo dizzy plug, remove leads from dizzy, mark the dizzy location, remove the 2 big bolts and pull out.
ideally when refitting, its worth checking the timing again with a timing gun just for peace of mind.
killerferret666
jimGTS wrote:undo dizzy plug, remove leads from dizzy, mark the dizzy location, remove the 2 big bolts and pull out.
cheers Jim, I have a timing gun so no issue there
jimGTS
Post by jimGTS »
just a note to say when putting back in, worth removing the cap just so you can rotate it so the dizzy end slots back into the camshaft.
